[ mclaren like performance.]
:) well all the modern Mclaren's will smoke our cars even modified ones.
But ...... the Emira's Look better !! IMO.
I had a CPO 600LT for a few months before I had to force it back to dealer.
My goal is to get as close to that level of feel/feedback/connection as possible, but with a manual.
Sydney Australia. Gets pretty hot here. So far, Ive only done 10 laps in one session on track and the temps haven't gone up over what you would usually expect. Mo heat soak as well. So I`m not considering any radiator upgrades at this stage. I see how I go after my next track session where I`ll have more time. Didn`t put a clock on it, but it did go quite well though(Touring and road tyres). I tend to progressively upgrade after Iv`e explored the limits in it`s stock form. I`ll go Nitrons after a few track sessions and see what the clock says after that.
Keep us posted which nitrons you go with and how you like them. I’m considering their electron set up, which allows for adaptive and selectable drive modes from cabin. Also can do front axle lift..
An observation. I am curious to why the JB4 only has two points of data if not using the OBD2. It uses the manifold pressure boost one and the boost pressure off the intercooler. While the TDI unit uses both of those sensors plus cam sensor or RPM sensor. I wonder how JB4 gets its cam/RPM information or if it just doesn't use it and why. I know more parameters are available with the OBD2 connection but let's speak as if it was just a person who's not going to use it on map one and two
I had JB4 on my Alfa Stelvio quadrifoglio as well as my ct4-v blackwing 6mt.
I believe the answer is the JB4 is really designed around the OBD connection as a source for tons of data.
While the obd2 connection may technically be “optional” it’s really an integral part of the system and absolutely should be used. It is not just for logging or whatever else has been suggested.
Why would they bother adding extra connectors for data they can get from OBD2 port. That’s their killer feature. I don’t believe any other piggyback systems have it. So other companies have 2, 4, 6 sensor data connections. JB4 w obd2 has dramatically more access and awareness than 4 or 6 connection systems.
Just my inference here, I don’t work there and am not an expert.
this is just me dreaming but it would be awesome if the vents could be electronically controlled and open only when the car is moving above a certain speed.
again, just dreaming..haha
- before anyone thinks I am competing or derailing GRPs thread, I'm not. I am an enthusiast just like you guys and have spent thousands of dollars with them.
You're over thinking it. Just think of an S2 Exige. Just some black mesh panels above the engine. That's all you need to let heat out. And don't worry about water going in. It won't affect anything.
Reactions: GRP
Here's a question I haven't seen asked yet: does the application used to change the tuning maps work through CarPlay or just the phone itself? CarPlay would incredible.
Just the unit itself. Not carplay compatible currently.
Agreed that would be awesome to have all the info show through carplay on the main screen! Hopefully they get that to work at some point.
Planning to get our shop car on the dyno soon. We will post some video and results to see what the difference in HP is between the maps.
We dont have 93 octane here so I have to make a trip to get some fuel to properly test it.
Looking forward to this!
Reactions: GRP
[But would be helpful for all to hear more feed back.]
Hey David, Yeah there have positive post for sure, with peoples butt dyno.
However, members with Draggy or RaceBox meters haven't reported substantial performance improvements in 0-60 (~0-100) or 1/4 that lines up with 90 extra HP. The results posted line up with much lower HP improvements. Think you could expect 0.2 sec off 0-60 for each 25-30HP increment added.
Do you have performance meter? If not, you should pick one up they are pretty inexpensive these days.
But i have with my draggy pro
Hi Greg,
A cooling engine under-tray, similar to what GRP already offers for the Evora, would perhaps be a more practical solution for extra venting, particularly since water and debris penetration into the engine bay would be a non-issue. Could that be developed for the Emira?
Keep in mind, the Emira has more cooling integrated into the stock undertray than the Evora had. I'm not sure if a revised cooling tray would improve engine bay temps.
is the Emira ecu somehow more capable than the Ferrari (Alfa) and bmw ecus of cancelling out the jb4?
Hmm, not sure I'd agree with that entirely, particularly with the notion of there not having room for further venting improvement.
I removed that under tray 3 times so far. I did find a layered aluminum panel on the inside part of the tray, which I presume somehow helps direct hot air through to the rear plastic diffuser tray and outward through the lower rear bumper black mesh. What I did not find however, was any open sections to let heat escape directly through the bottom of the tray. I noticed that his is present in the design of Evora's GRP Evora cooling tray with a couple of open breathing holes (I'd actually prefer if they were scaled louvered ones) as well as a wide rear facing vented grid.
Adding extra venting sections to the bottom of the tray, I'd imagine should help hot air escape directly and faster, which should help to lower engine bay temps but, admittedly, I'm not sure if this solution has any merit after all if somehow it causes a detrimental effect to the aerodynamic airflow of the car's under section. I'd prefer to leave that to the research and expertise of the product's designers. It was just an idea/suggestion on my part.
It's BOE's undertray (Not Greg's part, he just sells). I'm not sure I understand what you mean.
There's a front gridded opening to the undertray to try to 'scoop' air up under the engine bay and throw cold air over the exhaust and other parts of the engine that hang low.
There are no 'openings' at the back of that under-tray from BOE for letting hot air 'out'. Hot air generally speaking won't go out that way, and would mess up the diffusers purpose if it did.
The panels adds an opening to grab air, some 'kick ups' to direct said air to trouble areas for Evoras, and has a few cut outs to make room for exhaust bits (particularly aftermarket headers). Nothing in the design is 'pulling' hot air out of the engine bay. It is grabbing more cold air and then the air will follow any number of pathways out of the car. Most likely out the grate in the rear bumper above the diffuser.
yes and the Emira essentially is a closed system. it doesn't have enough venting topside when hot. which is why we all want louvered hatch glass.
Also Also.
BOE in their own product description effectively admit that this part is equivalent to the Evora 400 and beyond cars come with a engine panel that does what they are selling.
It's just that it can cause contact with aftermarket headers (which were likely designed before such trays were default).
Every other benefit BOE claims about their under-tray is that if you don't already have an Evora 400/430/GT undertray...they are hard to get a hold of, so buy theirs instead.
Well. Good news. The Emira DOES have the Evora GT equivalent undertray... so an undertray from BOE will not likely do anything for you.
Also Also.
Excellent, good news indeed, you can then dismiss my suggestion. I brought it up simply to explore an alternative to replacing the rear lid glass with anything that has holes, with or w/o louvers, which would invite water and debris into the engine bay. But that's just me.
