Yes I spec’d the tracker 😅 still no reply from lotus !!Did you option the tracker on your Emira? It’s an optional extra.
I learnt from someone on Lotus Facebook group, they had their car delivered to home. Their fobs were hid in the tool bag in the boot and the customer wasn’t even told about it. Go have a look.Yes I spec’d the tracker 😅 still no reply from lotus !!
Wow 🎉🎉🎉🎉🤣🤣🤣🤣🤣well that’s embarrassing, they where in the tool bag !! Thanks very much
Mine doesn’t work either. They’re sending out a tech on Friday (earliest they could send their senior guy apparently).Having the same issue, Tracker not active. Almost 20 mins on a call to Scorpian waiting for an answer, gave up in the end
I have an engineer coming out to me too - they were not able to connect to the tracker remotelyMine doesn’t work either. They’re sending out a tech on Friday (earliest they could send their senior guy apparently).
I found the unit actually and made sure the plug was firmly connected and the unit ID matched my account (won’t say where it is in public)
I could not log in via the app so called scorpion.Having the same issue, Tracker not active. Almost 20 mins on a call to Scorpian waiting for an answer, gave up in the end
See my previous post on this. It really shouldn't be where it is. Its on that basis I dont think its of much use at all. Any thief will have it out in less than 30 seconds. Sadly, they know what they are doing these days.Mine doesn’t work either. They’re sending out a tech on Friday (earliest they could send their senior guy apparently).
Thanks for that, called Lotus who put me through to Scorpion, all set up now and they have explained what to do with the fobs/app etc so now all good, they were very helpful...much better than the dealership who were the proverbial chocolate fireguard..ThanksSo you have the fobs which are associated with the tracker and it will unlock the tracker when they are in the car so it doesn't trigger any alerts.
More useful for me is you download an app and it has a 'phone tag' so when you are in car with phone it unlocks the tracker no need for fobs. You can also setup alerts not the app such as geo fences, monitor journeys, set It to garage mode for when its having work done etc
You might need to call Scorpion to complete the setup of the install for the tracker you should have got an email from Lotus with some app install instructions.
Yeah the dealers haven't set them up you did the right thing, I had to contact scorpion as well to finalise the setup.Thanks for that, called Lotus who put me through to Scorpion, all set up now and they have explained what to do with the fobs/app etc so now all good, they were very helpful...much better than the dealership who were the proverbial chocolate fireguard..Thanks
Did your dealer help register the tracker so you can login?Hello,
I get my Emira last weekend and try to setup the Scorpion GPS tracker.
I get a pre installation certificate from Lotus and 2 Scorpion trackers.
Can somebody help me and let me know what I should do now?
Downloaded the App but I can just login with an email adress that I do not have.
Thanks Robert
Scorpion tracker, does it work in Australia? | Australia & New Zealand | 1 | ||
M | Lotus App Issues with Scorpion Tracker | Lotus Emira Electronics | 41 | |
Scorpion S5 - Unites States | Lotus Emira Purchasing | 0 |
