I have a google sheet that calculates it, I need to add the Emira gear ratios, axle, and tire diameters to the sheet though. If someone has a link to a doc with the Emira's gear ratios PM me it and I'll update the sheet.
You can just make a copy of it.
I updated my sheet with Evora Standard/Close ratios. I didn't find a definitive source on the final drive ratios for the twin mainshaft, used what was out there. I calculated the adjusted ratios for 5th and 6th using the two final drive ratios I found for the split mainshaft. I think the Emira uses the close ratio set. Car is parked for winter, so its not like I can get out there with a GPS and hold 5th @ 60mph and look at engine RPM then compare to the table.
Based onto MWR website, which says 333kph in 6th gear at 7200rpm, I'm close as my table with the close ratio gear set shows 207.6mph (334.1kph). Most of its probably rounding errors.
