Good stuff or bad stuff?Updates:
1. We have confirmed unlocking and tuning for UK spec ECUs. Interesting note, UK Spec ECUs have a bunch more stuff in them that USA versions do not have.
Different computer.Boss, some questions:
- Since the valve acts depending on rpm I guess it would have a table controlling the opening positions too? Possible to tune this, say always open in track while tour stays OEM?
- If there are tables, can you post a comparison sport vs track? Folks still argue track being louder, but it contradicts what my tech says and what I think to hear (besides the obvious increased idle rpm ofc)
- FE Editions have +/- buttons on the steering wheel meant to control the ACC distance. ACC is not fitted on FE. Possible to remap the buttons to do something useful? Maybe switch maps / readline / valve control?
From the EG CertificateI didn't find a definitive source on the final drive ratios for the twin mainshaft, used what was out there.
| 1st | 2nd | 3rd | 4th | 5th | 6th |
| 3.538 | 1.913 | 1.407 | 1.091 | 0.9697 | 0.8611 |
| 1st - 4th | 5th - 6th |
| 3.777 | 3.238 |
Excuse my ignorance, what does these numbers mean?From the EG Certificate
1st 2nd 3rd 4th 5th 6th 3.538 1.913 1.407 1.091 0.9697 0.8611
Final drive
1st - 4th 5th - 6th 3777 3.238
CorrectAssuming 3777 is missing a decimal point
Just picked up my car after the ECU unlock and a 2.8 pulley installation. Pulls stronger across the entire power band, but I noticed it most on the low end. I really need to drive it more to get a better feel for it. The extra rpm's to redline and the extra time spent enjoying the glorious sound immediately had me smiling.
Griptec pulley (2.80" 7 Rib ZPE GripTec® 2pc Lotus 4 Bolt L3). Considering a dyno. I'll need to look into any tips or tricks on dyno'ing this car and then find a good local shop to do it. Would be nice to get one in case I do any more power mods in the future.Where did you purchase the pulley kit from?
Any plans for a formal dyno test?
Good to know. Just checked local car club posts, and a pretty highly rated shop for dyno's is close to me. I'll swing by there this week and see about setting up an appt for next week if that works on their end.Most important thing is to drive the car for a few minutes on the dyno until the ABS light comes on. Takes 30-60 seconds. That will signal that you’re in test mode.
Remotely updating flash is a huge benefit. That benefit will be highly dependent on your responsiveness to address issues and help troubleshoot. From a distance it sounds promising.We have a OTS map update we will be providing very soon (don't rush to the dyno just yet, we just finished testing this on 2 cars now).
more info on this this week!
the nice part about having a kit is you can easily flash updates
