Do you even need anti-freeze in your cooling systems there? Try distilled water and a bottle of Redline Water Wetter.
How do I drain to old one out?
I hope this helps...
Reactions: FST
An observation. I am curious to why the JB4 only has two points of data if not using the OBD2. It uses the manifold pressure boost one and the boost pressure off the intercooler. While the TDI unit uses both of those sensors plus cam sensor or RPM sensor. I wonder how JB4 gets its cam/RPM information or if it just doesn't use it and why. I know more parameters are available with the OBD2 connection but let's speak as if it was just a person who's not going to use it on map one and two
That's a good question for @Payam@BMS or @Terry to answer.
Drove my JB4 enhanced Emira to work this morning. Traffic was light some I could it a bit of a hiding through the gears. Seriously, if someone says they don`t feel much difference t in their cars performance, then think about sending it back to Berger to have it checked out. Remember, each unit was made manually(ie, one at a time). So production error is a def possibility.
You may be right, but I doubt it's that simple.
I wouldn't be remotely surprised if there is some trace left somewhere that shows something had been done.
Not to mention, if you think Lotus and / or dealers don't read this stuff you should think again.
I once had a throwaway comment (amongst hundreds of others) I made on a Ferrari forum quoted back to me and I never quite got the same treatment from the dealer after that... :ROFLMAO:
So I suspect Lotus know exactly who has done what to their cars, regardless of how the car may present to the dealer when taken in for work.
We should all use pseudonyms to avoid this, and post picture of random cars so that no one can identify us! Big Ferrari Brother is def watching. Just traded mine in today for Emira.
In really hot climates, there is going to be some big benefits to be gained with improved charge cooling and maybe water/meth injection I would expect. There’s no getting around it, all cars make less power in high temperatures and I think forced induction is even more affected than NA.
I have a track car (mid engine, NA 1.4l motorbike engine). It was previously pulling air from the engine bay. On a hot day inlet air temps were starting at 50degC and ending at 60 plus by the end of a session. I rigged up a basic cold air intake, fed by a roof scoop (not properly sealed or anything, no ram air) and now I’m barely over ambient on track, about 35degC yesterday. Engine feels significantly stronger sucking in this cooler air. I’m based in China, not UK, so maybe low 30s here ATM.
If it were me, I’d be focussed on those IAT and doing whatever I could to get them down.
Nothing better than meth in Dubai!
This makes a lot of sense. Given your analysis, you’d think Dubai streets would be flooded with meth injection. Could be a business opportunity.
I would totally agree with that. If there was a good design after market roofscoop id buy it in a heartbeat… also I am planning to replace the rear glass with Carbon or Plastic option.. unfortunately there is only 1 vendor atm making it and I dont like that design at all, plus on top of that im in dispute with them so would not buy anymore.
So the ideal situation would be that one of the Chinese vendors would design a roof scoop that continues with the rear engine bay as one.. im surprised that nobody in China has taken up this yet as the 4cyl turbos are more prone to heat in the engine bay.
Lets wait and see whats possible soon.
Btw the car is melting I believe 😂
What part is melting? I likely won’t have to worry about this but just curious. We’re in a heatwave here and it’s been 35 c
We have a vendor setup to make direct fit vented polycarbonate rear windows for the Emira (and Evora). Sort of an 675LT inspired type look like the picture below.
It would be a remove the glass, and install with urethane installation. If there is enough interest I will make it happen.
Im in for this, but the design of the vents should be flowing nicely with the side vents.. not like the picture above
Cool idea, but yeah... I'd also want to see it more louvered so rain wouldn't fall right in.
Rain, dirt, debri, rocks, leaves, etc.
