Just a heads up if you did not see it. There is a small clip that is used to attach the wiring from the start button switch to the shift rod. I'm assuming to keep the wire out of the way of the movement of the shift rods. It is not obvious. You may have unclipped it when you pulled the center console hardware out. I did this when I did the floating console mod and did not notice initially.
Thanks for the heads up!! Hopefully I can see in the cage to check for that without pulling the console out again.
@MAX FPS based on your initial picture I hypothesize like others that your “plate” was more neutral at first but due to the loose bolt shifted downward over time ultimately ending up in the bottom most position. You can see that your green lines do not match up in the pic signifying that the plate shifted from its original setup.
A previous poster showed the same bottom plate position which just based on the design alone feels like an odd choice to set up the car. I think it’s a loose bolt that shifts the plate and leads to suboptimal gear changes.
The plate screw was actually VERY tight from the factory, and you can see the compression outline in the plastic of where it initially was from the factory in my second picture where I moved it. The green line does line up in the first pic but you can see where someone drew it up over the screw hitting both sides of the washer, so it's a bit odd looking. No way it slipped down this low with as tight as it was.
I'd like to thank @kitkat and @Eagle7 for this ridiculously helpful tweak. My shifts are significantly smoother! :giggle:
I'd recommend this to ANYONE whose Reverse/1/2 shifts are more difficult than 3-4-5-6. I think the moderators should make this a sticky thread (not sure how to "at" them?)
I didn't think I "needed" to do this tweak, and I was very reluctant about pulling my console apart. I shouldn't have been. My biggest pet peeve about the car has been 1st-2nd has always felt like stirring a stick in a bucket of stones, and reverse feels like putting a truck in reverse. I've heard the transmission is the same one used in a truck, and every review has said it's a bit clunky and can't be "rushed". As long as I shifted slowly the gears have gone in, so I figured I'd be pulling apart my dash for no reason, or worse doing something that might leave me stranded on the side of the road. Kitkat's instructions and video are excellent and it's not nearly as daunting a task as it seems.
Obviously this factory-set plate position varies by car, and Lotus factory tech, and how rushed they were, but here's where mine was set from the factory:
Pretty much as far back as it could go!
And here's where I've set it now using the super-helpful Lotus technical manual page instructions @Eagle7 inserted early on to the thread. As per the manual, this position when in first gear "shoves the stick slightly to the right":
The angles are different in these shots but you can see the mark of the washer in the second shot how I moved the plate forward 2-3mm.
I did not need to clip the ziptie for the surround, or even unplug the starter button. Just pulled out the bit of extra wire stuffed down in the hole, and make sure you pull the console up all the way so the shift boot exposes the zip tie. No need to cut it, it just gives you plenty of room to work:
I'm going to attach a video here of how this plate contacts the reverse-lockout on the left. This may help some people who haven't done it visualize what this plate is doing. Note when you watch it how my plate only contacts at the upper-left corner for N to 1st gear, but the plate moves to sit flush against it when moving into 2nd. I'll get to that in the second attached video.
One potential issue I noted was that the whole adjustment plate is screwed down to that the silver metal block, which is attached to the silver "sleeve" around the actual shift post. You can twist the angle of this whole assembly a small amount by twisting the sleeve (see the video below), which makes a big difference in whether the plate hits with its full length flush, or just on one corner or another. The plate appears to be made of a tough plastic like Delrin, which will wear. I think this is why some users said they saw "metal shavings" after several thousand miles, or that the shifts eventually 'got smoother'. My guess is this is the Delrin wearing down, which is softer and better than metal shavings wearing and getting into your linkage, but ideally the contact/wear would be spread evenly along the length of the plastic plate. I can see some wear marks on the lockout bar itself at the left, which I believe is from the underside of the Delrin plate every time it's actually moved to/from reverse.
My question for the brains here: anyone know of a way to stop the "wiggle" in the silver sleeve? Having it align flush with the reverse-lockout seems fairly important to how it will wear over time. Mine sits flush going into second, wearing at the upper-left corner going into first.
End result: big improvement in N-1 and 1-2 shifts. 2-3rd is now "like buttah". In general, 1-2 now feels a lot more like the rest of the gears. Reverse is still a little difficult to get into once in a while, so I may need to move it even a bit further forward, or that may just be the way it is.
Thanks again for this hugely helpful thread! This is the best of what car forums can be: kind people sharing a tip that helps many others! (y)
PS - I'd add a flashlight, or better yet a headlamp to the list of tools needed. Made a world of difference trying to see the black-on-black tab of the console, and lighting down in the shifter linkage. Camera to document before/after positions of things is helpful too. Thanks for the tip to wear gloves to pull up the metal console tab. It does take some force to lift up and I would surely have cut my fingers without that great tip!
That as found position is crazy -- I noticed that you ended up positioning your 'as left' where mine was factory -- I moved mine a second time to match what KitKat had in his initial post with even better results -- give it a try!
Just a follow up from a week of living with the adjustment.
Was great the first day or two and then kind of went back to feeling tough and then opened it back up to realize that I probably didn’t tighten the screw enough or it might be needing to be a little bit looser. Played around with that and it turns out in the end that it’s perfectly fine for it to be tight as long as you follow the adjustment listed in the manual at the earlier part of this thread.
1-2, 2-3, 3-2 are all consistently smooth and easy. The only gear that that’s been inconsistent and there is reverse where it’ll be very smooth and other times be like preventing me from actually going into gear and it’s not the plate as I checked with the trim off to verify that there was no blockage. It seems reverse is kind of inconsistent and sometimes it likes you shifting a particular way or a or needs to be warmed up, not really sure.
I can live with the reverse being a bit crappy as the rest of the gears are now very consistent and I’ve also been torqued the screw down to spec and it’s been fine.
So in summary
1. Follow instructions for setting the plate from the service guide
2. Torque down correctly
3. Reverse may still suck, but when it works its smooth.
I think a little loctite blue would help
Thank you for posting this. These adjustments have made a meaningful difference for me also .
In the last three days, I’ve gone in twice.
Went back in to the shifter adjustments, you can see from the marker strokes that the factory had it in different place and it drifted since.
Once back in “as delivered” it’s much better. It’s still the worst manual shifter I’ve owned but it’s a meaningful improvement.
At least now when the car is parked the gate movement and shifter feel in first and second gear in reverse is clean.
However, underload it’s still a zoo.
It feels like the combination of transmission mounts and motor mounts and a transverse mounted V6 rocking underload is creating moving targets as currently configured.
I’ve got 4 shifter upgrades on hand or en route, hopefully by the end of that overhaul it’s decent and that’ll be great.
Also, I’m in touch with the gentleman who does the dolomiti shifter for earlier lotus models to see if he can make a version for Emira. That would presumably be a big improvement.
Attached photos showing initial “as found” and then attempt 1. Attempt 2 looks just like kitkat’s. Was the best for me.
Please post after your shifter experiments. I would love to know. Getting into first and reverse is a nightmare for me
Have you opened yours up to check the location of the lock out plate? Shifting mine up to where KitKat put his helped a lot. It’s not hard. Def worth it
This was very helpful and fixed my 1st gear issues. Hardest part for me was getting the center console unclipped. I discovered that the easiest way to get the first clips undone was to use the short end of the trim tool as a hook and pull straight up on the console.
After the first clips were undone, you can just grab the sides and the rest pops out easy.
