Update on my JB4 + WMI setup for the AMG Emira. Been logging a bunch in Sport and Track.
TLDR: 490hp, car RIPS
After about 700 miles of testing so far I have settled on some settings that are stable. I might lower the boost additive to 40, will test that soon just to see if it tames overboost near redline. The methanol is providing exceptional cooling and anti-knock...I'm seeing on average IAT 10-15F above ambient after repeated pulls and hours of canyon driving. There's no observable heat soak and engine water temps are low.
Setup
  • JB4 on Map 7 custom tuned at DRS with Terry's remote help
  • Boost Additive set to 45 (this is how much boost is requested as methanol spray ramps up)
  • Burger WMI kit, 100% flow at WOT, methanol ramps up at 15 psi
  • High-flow cat, Weistec charge pipe, Aerie exhaust
Boost by Mode
  • Sport: ~30–31 psi sustained
  • Track: ~32–33 psi sustained
Power (SuperFlow Dyno) - usually the shop uses a 20% loss on their dyno which is verified with all the cars I have used there (Elise, Alfa). To be conservative I also show 15% loss. So let's call it averaged, the tune is making around 490HP. My car stock (charge pipe+hi flow cat+exhaust) was showing 342 whp on this dyno for reference, and is probably making around 415hp stock. A pick up of around 66whp/80hp -
Pump 91 Cali gas + map 7 (methanol on)
  • Wheel: ~407 whp / 370 wtq
  • 15% loss: ~479 hp / 435 ctq
  • 20% loss: ~509 hp / 462 ctq
Intake Air Temps (IAT) with WMI
  • WOT median IAT: ~83–91°F across recent logs (ambient 75-80F)
  • IAT stays flat under load once WMI is active, no heat-soak climb
  • Meth flow = 100% at WOT, consistent across pulls
Timing / Knock Health
  • Average timing under load: typically low-teens to high-teens
    ~12-18° average with clean recoveries
  • No pattern of sustained timing pull, and no throttle closures under boost
Notes
  • Rear O₂ (P2270/P2271): shows up intermittently because of the high-flow cat + WMI. ECU trips lean or rich codes from the cat, previously before the JB4 it was showing rich only and the normal efficiency code.
  • Stock my car was giving me overboost code when we installed the Weistec charge pipe and hi flow cat. We will recheck boost sensor connection but everything seems to be working fine with the JB4. I get overboost code in Track mode if I trip the rev limiter for longer than a couple seconds so I have been intentionally short shifting around 6500. With the dash delay and the car just sounding like it's going to explode at that point I feel more comfortable short shifting a little, power curve shows no real benefit maxing out revs each gear.
  • Engine Oil Temp channel does NOT work in my JB4 app when I have live gauges going, anyone else see engine oil temp active?
  • updated bluetooth module and app do not start live connection until the wheels are moving (might just be weird glitch on my car)
I'll take some photos of the methanol system and post the same data in a separate thread since V6 owners will get great benefit from this as well.
Very good number for your setup, nice!
Reactions: Kaz
methanol plus forced induction always a great thing! basically it's just running race gas all the time you can just crank up timing, since we don't directly control that with JB4 it's just boost request against methanol spray ramp up. With the new ECU flash you are doing they can control everything now, really exciting! Based on what the AMG A45 S guys get with methanol and stage 2 we should see 500+ easy on the I4. And if they can control wastegate we can start experimenting with hybrid turbos (!)
Just want to give another perspective on the install. I’m not very mechanically inclined; other than changing the oil or brake pads and basic bolt on mods. That being said. I did the install in my garage on ramps. It took about 2 hours and a lot of that time was spent tracking down the right tools. The instructions from burger were straight forward and accurate. The concept of the installation was super easy. Getting access to the bottom sensor was the only difficult part. I didn’t use any special tools and if I had to do it again I would. ALTHOUGH, I would recommend trying to get access to a lift. It was definitely cramped under the car just using ramps. Trying to maneuver my hands and arms into the correct position to access sensors and bolts was the biggest pain of the entire install. Moving/prying the intercooler forward made a big difference. I used a long flat head to reach and disconnect the stock sensor. The stock sensor had enough slack to pull down and plug into the jb4. I worked the other end of the jb4 into place as best I could with my hand and pushed it the rest of the way with the screw driver until it “clicked in place. If you’re into DIY I would say it’s worth giving it a shot, but I highly recommend trying to get it on a lift to do it.
On another note, can anyone advise on sending logs to burger? I’m plugged into the OBD and connected to Bluetooth. I’ve stored three logs so far and I can’t seem to email them to myself. I’ve tried multiple times to two different emails and they never come through to my inbox or spam. I’m using the jb4 mobile app that cost $.
I just sent my logs to myself, pay app worked fine. I would reach out to them. They are very responsive
I'm only using the new bluetooth module and using the new free app and logs just stay in the log tab by date created and I can access and email from there even if the phone isnt connected to the car. Paid app might operate differently, but yeah they are highly repsonsive
Setup
Boost by Mode
Notes
I kept forgetting to reply you about your app not connecting to a live feed. Remember a few weeks ago I reported I was not able to connect after V3 firmware? I found out later I can sometimes connect when it was in motion and sometimes not, but anyway I talked to Terry about it and they sent me a replacement and it is all good ever since.
Reactions: Kaz
For those who have run logs on the jb4: any indications of where the fuel limitations will come into play? curious how fast you may run into a fuel flow limit.
For those who have run logs on the jb4: any indications of where the fuel limitations will come into play? Fuel-it makes a kit for the m139 for running ethanol, but curious how fast you run into a fuel flow limit.
What kit? I only see one for the old Mercedes c43 which was a v6.
Heads up, had some issues with my jb4 (couldn’t see boost, low boost warning, and couldn’t read fault codes with obd plugged in) and terry identified an issue with the beta and released a new beta since 2 days ago and seems to be working fine now
which app software version do you use
LTFT at 34% ??? God... that's a lot! How much more boost is it making?
I'm currently waiting for the JB4 to arrive so I can run some tests. In the meantime, I've been checking the wiring and I’m planning to tap into the CAN bus near the engine bay instead of running a cable all the way to the OBD port.
I’m currently awaiting the arrival of the JB4 unit. In the meantime I too am considering a “splice” into the wiring loom that leads to the OBD cabin port.
I would prefer to mount the unit not in the engine bay where engine/turbo heat is generated. There must be a hidden but accessible place where such a joint using proprietary splicing clips (no cutting of wires) can be made. Once the specific coloured wires (in the loom itself) leading to the OBD port are identified a choice of mounting position becomes possible……… (wishful thinking comes into play here!)
Has anyone identified the pertinent CAN BUS wires in the wiring loom that terminate at the cabin OBD plugin port?
The other consideration would be a readily accessible isolating switch, since there will be no physical OBD connector plug to pull out in the cabin port itself. This would be necessary should a drain on the battery be associated with the OBD cable connection as some have suggested. It need not be in the cabin itself, but perhaps near the area where all wise sports car owners connect their battery trickle charger e.g. CTECK.
Your comments both pro and con regarding any of the above are most welcome, and I thank you in advance.
If you don’t want to mount the jb4 in the engine bay then you will have to extend the jb4 harness (one that goes from jb4 to the sensors). Should be do-able, you can use the rubber grommet that is located in the interior left rear where they store one of the fuse boxes.
If you are talking about the obd connection, I used the rubber grommet I mentioned about and routed it into the cabin like that.
Thank you so much for your comment and advice, Milk242. I’ll add your insightful advice to the list of options. Fortunately, I’m in no hurry. Next track day is 3+ months away. I recon I’ll have it sorted by then. Thanks again.
Greetings all. Has anyone come up with a neat looking solution to attach the JB4 module to the top of the (2.0T) ECU. I realise zip ties have been mentioned. As a last resort I would consider using zip ties in conjunction with either double sided tape or Velcro (hook and loop tape) to avoid dislodgement. However, there will be I’m sure, some really switched on ‘cookie’ with a better looking fixture than my simple idea. Thanks heaps for any ideas.
I bought the bracket made by darkworks design who is a member on this forum. I had to mount it on the right side of the car since the jb4 cables would not reach if mounted on the left side like the v6 edition. IMO, it’s the cleanest setup, you can’t even tell the jb4 is there.
Thank you so much. Did you happen to take any photographs showing the final resting place of the JB4 module? If so, would you kindly post them for viewing.
Kind regards,
Richard.
Kind regards,
Richard.
Thank you so much for the pics. I agree, the cables from the JB4 module being the length they are do limit mounting positions. The ECU positioned above the air filter benefits from fresh cool air (we would hope) drawn through the external rear side duct. Finding something similar for the JB4 is a challenge.
