Do you even need anti-freeze in your cooling systems there? Try distilled water and a bottle of Redline Water Wetter.
No need.. the temp never drops in the city below 15c in the coldest months night.
How do I drain to old one out?
I hope this helps...
Reactions: FST
An observation. I am curious to why the JB4 only has two points of data if not using the OBD2. It uses the manifold pressure boost one and the boost pressure off the intercooler. While the TDI unit uses both of those sensors plus cam sensor or RPM sensor. I wonder how JB4 gets its cam/RPM information or if it just doesn't use it and why. I know more parameters are available with the OBD2 connection but let's speak as if it was just a person who's not going to use it on map one and two
That's a good question for @Payam@BMS or @Terry to answer.
Drove my JB4 enhanced Emira to work this morning. Traffic was light some I could it a bit of a hiding through the gears. Seriously, if someone says they don`t feel much difference t in their cars performance, then think about sending it back to Berger to have it checked out. Remember, each unit was made manually(ie, one at a time). So production error is a def possibility.
I am still waiting reply from Burger tuning
