DIY: V6 Manual Transmission Fluid Change
jp129
This information is purely my experience and serves only for your entertainment. I will not be liable or held responsible in what you do with this information. Please proceed at your own risk.
Tools needed:
4mm HEX/allen socket
7mm socket
9mm socket
10mm socket
Long socket extention for the 9mm socket
Ratchet
22mm Open ended wrench
Brake Cleaner
Long reach funnel
Oil Drain pain
Towels/rags for clean up
3.5 QTS of your favorite transmission fluid (Spec calls for API-GL4 75w80 transmission fluid) - I elected to run Amsoil 75w90 API-GL4 Transmission fluid
Access:
-Remove Rear diffuser using the 4mm hex & 7mm socket
-Remove engine lower cover using the 10mm socket
-Remove top side engine surround covers
Asess current fluid level/fabricate dip stick:
-Locate the transmission fluid fill hole/ transmission oil cooler return fitting
-Thoroughly clean the area around the fitting as to make sure no debris will fall in when you remove the fitting
-Can of brake cleaner seemed to do the trick in short order, blasting the debris away from the fitting
-Using a 9mm socket and long reach extention, unfasten the bolt holding the fitting to the transmission
-Fabricate a dipstick as per the service manual
-With your fabricated dipstick, carefully insert the dipstick and assess your currently fluid level
-Make note of this fluid level as you will be refilling your new fluid to this level
-Once you're done recording your fluid level, take a shop rag or towel and cover/plug the hole to prevent debris or foreign objects from falling in while you work on draining the fluid from underneath.
Draining the old transmission fluid:
-Look for the transmission fluid temperature sensor (it'll be the lowest point on the transmission case with an insulated line running to it
-Clip the zip tie that's holding the heat wrap around the sensor and slowly peel back the heat shielding to expose the connector
-Positively unlatch the connector and remove the connector from the temperature sensor
-Now using a box end 22mm wrench, unfasten the fitting from the transmission case. Make sure to have a fuid catch pan ready as fluid will start to drip as you unscrew the fitting
-Take care to retain the sealing rubber washer - mine showed no deterioration, so I elected to re-use. Best practice is always to replace, but I've reused them with no issue - YMMV.
-Tip: Use the fitting as flow control with your hand so that it doesn't splash onto the exhaust Y-pipe or drain too quickly, making a mess
-Drain all the old fluid out. I got about 3QTS out.
-Once all the fluid has been drained, put the fitting back in and snug tight - I couldn't find the torque value, but I usually just do this by feel anyway.
-Reconnect the connector to the temperature sensor. Ensure the latch is positively connected.
-Pull the heat shielding back in place and use a zip tie to secure as it were from the factory
Filling with new transmission fluid:
-Use a long reach funnel or a contraption of your making, put the funnel into the top side fill hole
-Refill roughly what you drained out and periodically check your dipstick to ensure your correct fill level
-Once you reach your previously recorded level, you're good
-Lube the oil cooler return fitting's o-ring with some trans fluid and re-install the fitting to the transmission
-Snug the 9mm bolt
-Reinstall the engine surround covers, lower engine cover, and diffuser in reverse order.
-Job complete.
Hope that helps!!
Thanks for the writeup! Amazing detail! Very much appreciated!
How does it feel? Improvements?
I haven't driven the car yet, but will later this week and report back.
Finally a good write up on this, thank you so much!
Thanks so much. I've been hoping someone would do this also.
What did you use to make that dipstick?
I used a motorcycle fork oil level tool (since I had one already), but a forum member here printed one out for me as well.
Quick update: I just test drove the car and shifting is smoother in all gears, cold and operating temps in 80F ambient temps. 1st and 2nd gear shifts is much improved. I suspect this feeling will be short lived as I've experienced similar sensations on other manual trans vehicles after a fluid change, but we'll see.
My car has 5700 miles on it and this is the first trans fluid change. Amsoil 75w90 API GL-4 seems to be working well with this trans. Will post a long term update after a few k miles.
It'll surprisingly hold-up. I use to change the transmission/differential oil in my Evora every 20K, because the first time I did it, nothing but black water like crap came out. People always joked with me that these modern engines and transmissions are built to tight tolerances and that changing lubricants often is an old school POV and flat out waste of money. The reality is, the bulk of your wear happens early on. So, getting new lubricants in early is key. Once you see that original fluid and feel the gears afterwards, most will ask themselves why they didn't do it sooner.
Thanks for the data point. That'll be great if it can keep this feel for 10K+ miles.
My S2000 is similar, but within 5K miles it'll go back to feeling notchy, but there are a few fundamental differences in that transmission compared to the Evora/Emira. It uses 1.8QTS of fluid for drain/fill and it does not have a fluid cooler, so the volume of fluid is subjected to more temperature and shear.
Having close to double the volume AND a cooler should prolong fluid life substantially.
Thanks for the write up. Would you (or the other member) be willing to share the STL for that dipstick ?
My AP1 S2K was my very first rear wheel drive front mid-engine car. Man, shoulda kept it. Only ones left are museum pieces or duct taped wreckers that the kids have exchanged hands a dozen times.
I just wrapped up the transmission fluid change myself.
One note: The bolt holding my fluid return tube to the transmission case had an 8mm head, not 9mm.
I designed a dipstick and would be happy to share it but the forum is not allowing me to upload an STL. Thoughts?
I changed mine to Redline a few months back and I swear I can feel the difference, much smoother/slicker.
It was the same for me. Amsoil MT-90 and the shifts were significantly smoother.
Try compressing it as a .zip file and see if that'll work.
Sure, let's give it a go!
This ZIP file contains only the STL for the transmission dipstick I designed.
I printed this upside-down out of (white) PLA with support generation enabled for the flange.
It worked perfectly. The inset rings are set at 10mm increments for a visual fluid gauge.
