Lotus Emira i4 AMG Bosch MG1CP002 ECU Flash Files (360 HP & 400 HP)
ManuelB
Hi everyone,
I'm looking for the original ECU flash files from the Lotus Emira i4 AMG, equipped with the Bosch MG1CP002 ECU, specifically the 360 HP and 400 HP versions.
My goal is to compare both factory calibrations, identify the differences, and potentially develop a software upgrade to bring the 360 HP version up to the factory 400 HP specification.
I can already source the 400 HP file, but I'm still looking for the original 360 HP flash file.
Does anyone have access to this file or know someone who could help?
I'm also curious whether anyone has already compared these two versions and the differences between them.
Any information would be greatly appreciated!
Thanks in advance!
This would be a great stepping stone whilst waiting for a full remap option. I'm afraid I can't help with the file but if you have a means to flash the 400 file onto the ECU then why would you even need the 360 file?
Hi Andy, thanks for your reply!
The reason is that flashing the 400 HP file directly onto a 360 HP ECU isn't necessarily that simple.
Even though both versions use the Bosch MG1CP002, there are several technical factors to consider.
The ECU may have different software versions, internal flash layouts, EEPROM data, coding or processor-specific configurations. The application software and calibration data must also be compatible.
Simply writing the complete 400 HP flash could result in incompatibilities between the flash and EEPROM, checksum or signature validation failures, or even an ECU that refuses to boot.
That's exactly why I'm looking for the original 360 HP file. I want to compare both versions at binary level, identify the actual calibration differences and determine whether the power increase can be achieved safely by modifying the relevant maps while preserving the original ECU software structure.
If both versions share the same software base, the process could be relatively straightforward. Otherwise, it requires a more detailed analysis.
I'd rather develop a proper, reliable solution than blindly flash a different factory file and hope for the best! 😁
I've done that for a few Mercedes A45 variants from 380 hp to 420 hp.
Thanks for explaining in so much detail. I really hope you can find the 360 file. Please do keep us updated on your work.
