For my weekend project, I swapped out OEM rotors and pads. Pretty straightforward removal and installation.
TLDR: new setup is awesome, improved stopping power, have to relearn brake pedal modulation
1. Be sure to disengage electronic parking brake from cabin while engine in ACC or ON. If you forget to do it and you have rear wheels off, you can do it then as well.
2. Rotor weight comparison (in lbs):
FRONTS
REARS
Yes, rears heavier than OEM (+~2.5 lbs each) and sleight weight savings in fronts (-~0.2 lbs)
FRONTS
REARS
