Doing some research on the latest AMG M139 engine. Looks like the M139 can operate at higher boost. Assuming proper cooling. Latest version operates at 40 psi. Emira version is already at 9 to 1 CR. Factory power output is rated at 469 HP, this engine might also have a very larger alternator to charge hybrid powertrain that might be zapping some HP.
[The 2.0L gasoline 4-cyl. in the C63, codenamed M139, is a development of the unit unveiled in the latest C43 and SL43. In the C63, it adopts a lower 9.0:1 compression ratio so it can accept greater boost pressure from a larger turbocharger. At full load, there is up to 40 psi (2.8 bar) of boost pressure, according to AMG.]
Hi Guys, no offence.. im gonna play devils advocate here. Having installed the JB4 and running map 2 for a week… i feel the performance increase is like a placebo effect. All these people who claim the map2 power is felt and that is is soo much better and it should have come from factory like this etc..
Have you all done a side by side comparison with another Emira?
We did, see the difference below, the reason again might be due to the hot climate but again we are comparing apples with apples here.. one emira with grp airfilter, milltek valve controller and decat as dynoed by jb4 and the otherwise exact same setup with jb4 map 2. See below the videos and let me know what you guys think of it.
Presumably the DV color Emira has the JB4 while the NG does not. That being the case, and considering the short distance run of your test, the HP enhancement from the JB4 is very noticeable with the DV pulling away on 1st and 2nd gears. Imo, this gives credence to the JB4's effectiveness.
Interesting for sure - could it be that your JB4 module isn't working properly? Your results are contradictory to what several dyno's have shown as a significant performance increase with the JB4 installed.
Maybe? I need to send the logs for analyse. Will report back, as of now (as you can see) there is very little improvement
Yes
And I’m the “stock” emira , only 3rd cat delete + Milltek open valve controller
Only logic reason could be humidity + weather 45 degrees ? I don’t know but I would expect more to be honest , and I bought it also but still not install it
Why don’t you try and install and try go for a drive. If your car performs strongly, and feels significantly stronger than the test car, then you know the JB4 is not functioning properly on that car. I’ve been around various lotus products for more than 20 years and have had a significant amount of t of track time in them..so it is fair to say that I know what it feels like when a car is modded. It not like adding a sports exhaust and the extra noise gives a placebo effect for how fast it feels.
Very true, last time I increased boost significantly on one of my cars; I had to up the intercooler (4 times larger, with a larger intake air duct). Yes, people should be careful.
I do wonder - with the piggyback essentially overriding the boost value (both cars) sent back to the ecu. Will all engine management safeguards still function, I;m sure most people are going-in eyes widevopen, that the issue may arise.
I’ve check with my lotus people(they developed the harrop 1909sc for the v6), and they said the ecu still functions normal and will take over if certain parameters are exceeded.
Not really sure what your second and third videos were about, since it was only on the first one that one could hear the 3 beeps for take off with the 2 cars relatively lined up.
To be fair, there could really be something defective with the Verdant's JB4 module, but it could also be that your expectation of its performance enhancement is not very realistic. It's a well known fact that a stock Emira isn't super fast, but it's also not exactly a sedated turtle. For instance, my expectation of the JB4 vs Non-JB4 never resembled an outcome like this...:)
keep the redundant reviews coming in when you guys install the jb4. Always interesting to read. I don’t think we have a lot of impression reviews on the i4 either.
Or another option is to unplug the jb4, pull the battery for about 10 minutes. Restart it. Then switch it off and keep the key away from the car for about 10 minutes, then replug the jb4 and try again.
Reactions: TFS
It was hard to do many side by side videos.. the second and third are done at the same as first but due to conditions it was staggered.. both driving at the same speed and then push on the 3rd honk. The only difference in the 2 cars was that I (DV) had 2/3 gas and titanium exhaust in and my friend (NG) 1/3 gas with oem exhaust..
thats the only difference the 2 car had.
The impression about power increase on the forum was that when you push it at least the car would run away a cars length from stock and that did not happen unfortunately..
Not trying to be rude, but are you new to modding? More power means more heat, no matter how you increase it. It means more strain on components, and requires more diligence to maintenance (oil/filter changes, etc.). It's not unusual to have to improve the cooling in some way. There are some dedicated and experienced modders on this forum, so I expect we'll see some solutions being talked about soon.
Right now the JB4 is new to everyone, so give it some time for issues to be discovered and resolved. It'll happen.
Of course I know there will be more heat, but I want some cooling options because it is mostly a track day car and I don't want any more issues.
JUBU has some parts and wanted to know if anyone has installed them?
I originally had the TDI unit. Felt pretty fast. I installed the JP4 and it feels much slower using map 2. Not sure if something is wrong but no codes. What should the boost gauge be on the app? The increase only or the total psi? It is only showing about 4pi
Tried a search and can't find this Snowtech intercooler and cooling reservoir for sale online. Where can I buy these parts?
Does anyone know if anyone else makes this or will make these parts other than Snowtech?
I have seen a few different setups but Snowtech is probably the most reliable and track tested. Boomgear has put a lot of track time with his snowtech and so far so good. Intercooler is 1700 USD and reservoirs are 1400 USD.
If you haven't done it already, going with distilled water and Redline Water Wetter in the cooling system should help. They claim 20° cooler, but from what I've seen it's generally about 15° cooler, but that's at least something. If you don't have winter freezing issues, you won't need anti-freeze. Distilled water and Water Wetter would be fine for track use.
Snowtech seems pretty popular in China and I’ve heard they work well. I don’t think Snowtech do any parts for the V6 Emira, only for the I4. I might be wrong, but the Snowtech parts are intended for the AMG A45S but they also happen to fit the I4 Emira.
Not too o many V6 Emira in China, the vast majority are I4.
@675430VME Snowtech are only offering the charge cooler and matching radiators, or they have more parts available for the I4 Emira?
I would think any m139 chargecooler would work. Intercooler is another matter because of the mounting
But your 1st posted video does show the Verdant pulling ahead in what seems to on what seems be on the first two gears. Hopefully there will be more such comparisons to get to a consensus, but in the meantime, you should send a couple of data logs to Burger so they can determine if your Module is in fact performing optimally.
