In the posts above? Youtube link?
Hard to get a 'better' video than that because its a tight space and your hands and the shifter will be in the way of any meaningful views.
Did you ever get around to doing that video? Inquiring minds wanna know (and possibly proceed with your help) :)
Thought I posted it here:
Woops... yep.. I missed that... THanks!
Had a journey this week and struggled to get into first and second for a 75 mile journey - it came and went but was “interesting”. I panicked thinking I’d got some horrific issue, followed this and hey presto it’s all sorted.
My adjustment nut was VERY loose!
Hey kitkat, what exactly do you mean by not smooth? For mine, getting into 1 and 2 it feels a bit rough, sort of like a rocky feeling. If I go back into neutral and then try again once or twice more, it feels smooth. Is this the feeling you’re referring to?
If you go into first from neutral at a stoplight to get started, do you find it easy or difficult to get into first gear, like physically getting it to there or does it sometimes feel like you’ve missed the shift gate. Do you ever find it easier to shift into seconds and then first?
If you can resonate with those you should adjust the lockout plate.
Okay got it. For me, 1, 2 and reverse are rough to get into and I question whether it is fully in gear or not.
100% do the procedure then, the lockout plate adjustment will fix this, it'll make your car so much more enjoyable to drive.
After installing the GRP short shifter, I found it harder to get into 1st and 2nd gear. It wasn't a problem before the install. Does anyone else experience the same? I will try the adjustment to see if it helps.
I found mine would sometimes struggle to go into reverse without requiring some force. Someone told me to put it in 1st briefly before going into reverse. This seems to work, and it then glides into reverse. I'm not sure why this works.
I should probably try this adjustment, but I'm hesitant in worry of breaking something.
I've also driven 3 different Emiras. All 3 had a gearbox that felt quite different to operate.
Why is it so inconsistent between cars? Do they even bother setting them up properly at the factory?
Do the adjustment you'll wonder why you hadn't earlier, it's super easy.
Likely the poor guy who has 18 minutes to install the whole shifter assembly and adjust the cables just didn't have time to do it perfectly. This is Lotus we're talking about afterall.
I’m running into this issue. Just curious, anyone had their dealer fix this or is that a bad idea?
I’m nervous to try and fix this lol. It’s my first fancy car and I always break stuff when I work on my cars.
Your dealer should be able to handle it just fine, tell them the reverse lockout plate needs to be adjusted.
@kitkat I'm at about 3K miles on my car and drive it like it's meant to be driven -- I have the GRP short shift installed (set in as received position) and like it very much -- the single complaint I have with my car is the shift from 1st to 2nd, no matter the RPM. It's a 2 step process -- pull down (feels like it finds a notch), then pull down again (into gear)...similar situtation 3 to 2 with rev match. Not smooth whatsoever, I dont think I could make the shift without a firm grip on the shifter knob.... all other gears are butter and require little effort. The 2 step process is painfully slow, do you feel the adjustment described in this thread would address this concern? Thanks for your input!
I think what you’re describing is more intrinsic to the Emira transmission unfortunately. Anything dealing with 2nd gear for me is a little slow or forced. This adjustment only fixes any binding you might have between with 1-2. It doesn’t hurt to try, and it’s such an easy procedure.
I thought that might be the case, but as you mentioned it wouldn't hurt to try it anyway. Thanks bud.
@kitkat I finally did this adjustment. you were right, it took 15 min.
The hardest part was lifting the middle black tab, but I noticed that when you lift the very edge of the tab it unseats rather easily vs. trying to pull the whole tab.
My shifter was already very good. However, I've noticed a small but welcome improvement going N-1 and even the 1-2 gear change. It just pulls into place which you kind of expect on upshifting. For me all the upshifts are super smooth, N-1, 1-2-3-4-5-6. Downshifting is fine but it requires a lot more force. I think again, this is inherently the nature of our shifter mechanism.
After shifting needlessly for 15 min I remembered two things. One, manual transmission is so much fun! Hammering the throttle and ripping through a few quick shifts and downshift/rev matching, etc. It's just the only way to go (for me). Two, is that I can shift pretty quickly with the GRP short shifter. This is not a humble brag. I'm genuinely surprised how quickly you can shift this manual. Despite its notchyness - I think the positivity of the gears and the short shifter let you really slam into gear with a lot of confidence and speed. It reminds me of the sequential shifters you see on WRC where the drivers just slam it into the next gear. Downshifting, however, is not fast due to the force required.
When downshifting, do you think the "force required" is related to the work the synchros are doing?
Just did this mod and it is probably one of the best most impactful mods I’ve ever done on any car.
I went from being ok with my gearshift lever to absolutely feeling like its almost as good as my Japanese shifters ( mazda, honda, toyota ). It was always decent and pretty good for a lotus ,especially compared to my GT which was good , but the Emira was a bit better.
I was suspicious it would make that much of a change. I made sure to practice with it before the adjustment and while it did feel like sometimes I was going through rocks between one and two, the reverse with still engaged, but just be a little bit a pain so I wasn’t expecting very much.
Holy crap what a night and day difference. Absolutely so smooth to get into reverse now and very easy to dothree-point turns and even high RPM shift from one to 2nd. This used to feel very difficult like it was holding itself back but now it was much much easier.
I can honestly say the manual in this car now feels great and very acceptable and it should’ve been like that from the factory. Changes the experience of the car completely as I now can drive easily in traffic or shift at lower speeds in those gears and just feels smoother from 1 to 3
