Scoates' Magma Red Emira
scoates
scoates
Scotland
  • #61
Checked the drain holes, no water coming out of them but it did feel damp inside with a slight water droplet on my finger when I took it out. When I did this checking the bottom of the door where the drain holes are I spotted more bubbling down there as well...
Porter
tap tap... is this thing on?
DC/Virginia, USA
This is awful. Either you have entirely defective door panel material, or these cars possibly have a design defect in the water drain system to get water out of the door cavity. Every car collects water there due to the nature of a roll-down window, and every manufacturer comes up with a strategy to get the moisture out.
kitkat
Emira Degenerate
Mountain View, CA
Why can’t it be both? This really is becoming an issue of when not if.
If Lotus doesn’t approach this with a TSB, what are we doing? Drilling holes?
Porter
DC/Virginia, USA
Right but you get what I'm saying, this type of composite material is always going to absorb a little bit of moisture if there's no effective drain. You can't fill something like that with water and let it sit for days or weeks and not expect some issues. The drain thing is a serious problem even without the paint issue.
VL3X
Delaware, USA
They literally told an early buyer to do just that. I don't think it was scoates, but didn't someone have an issue with water getting into the hatch and freezing? Lotus told them to drill a hole in it to let the water drain.
VL3X
Delaware, USA
It was @ott - See their post about it here.
Temporary fix as advised by Lotus is to drill drain hole. Lets see how long it takes for new hatch to be delivered ?
Go Kart
… has a HUGE member
Utah
I swear the more negative aspects of this roll out I read makes me want to veto my wife’s patience for this car in our garage.
She wants a fun manual car though, so there aren’t many options out there… and I doubt she’d want anything else at this point.
scoates
scoates
Scotland
  • #69
On the bottom of the door there seemed to be 3 holes, one nearest the front of the door which is also the furthest down where water would drain there was no plug in the hole so should allow water out, the others had rubber plugs which I removed and that is where I felt the slight moisture. The whole base of the door was wet and dirty as it forms the top of the air duct but I'm sure some of the moisture came from the inside rather than the outside...
scoates
scoates
Scotland
  • #70
As a fun manual car I still maintain there isn't anything better out there for driving feel and engagement that you can still buy new. My car was one of the earliest so it is possible a lot of these issues have been solved, but as time goes on I'm likely to discover more as an early buyer. It doesn't bother me too much, but it is the response, or lack thereof, from the dealers with regards to fixing it that is getting more and more difficult to tolerate.
scoates
scoates
Scotland
  • #71
Just gave the car its first proper wash of the year and wow it was bad... Paint blistering on BOTH rear quarter panels as well as the driver door and also paint cracking along the edge of the left hand side rear quarter panel where it meets the boot lid. Not too happy...
I've been in touch with Lotus Customer Care directly, bypassing the dealer, asking to escalate the issue further to hopefully get a resolution. It is getting to the point where I feel it will need to go back to Hethel for a new body and a rebuild!
Wonza
Manchester
Reject it. A lot of us with the blisters have already done so. Don’t take this BS. Down the line, it will only get worse.
kitkat
Emira Degenerate
Mountain View, CA
This is insane, they just need to buy back the car at this point.
Go Kart
… has a HUGE member
Utah
Your particular car is lemon. I’d reject the car and cut your losses.
scoates
scoates
Scotland
  • #75
Definitely considering rejecting it, but not sure if I can since I've had it since Nov 22. If I can reject it for full refund then ideal, or exchange for a new one, or back to factory for rebuild. Any of those would be good options. But if I rejected it now and they gave me only a partial refund since I've had it for so long then I'd rather they repair it.
Beardedbradley
KENT
Lotus need to sort this asap. If a factory return is the option then a replacement courtesy Emira is required as correction to your car my take some time…..its the least than can do and Im sure they have plenty of orphaned stock to give you.
Wonza
Manchester
For your information. I got most of my money back, nearly one year old. Depends on mileage. Or you could ask for a replacement vehicle if you wish.
