Paint blistering issue update
Has your Emira been affected by paint blistering?
  • Total voters
    147
  • Poll closed .
@jeidmann
That looks like it is on the rear bumper (?) - so it's not the problem with the composite bilstering we are talking about in this post.
The bumper is molded plastic and also quite flexible. So either this has not been painted properly - it some impact has bend the plastic in, lifting the paint and the plastic would have sprung back into shape.
Apologies if I've got the location of this wrong. Any more details about this?
@jeidmann
No impact. Yes, rear bumper. Regardless of the underlying material, blistering paint appears to be a chronic problem. Given it's a multi-surface material problem. Deductive reasoning would lead me to conclude the root cause to be a painting process problem.
I see where you are coming from but your issue looks completely different to the composite bubbling issue. Neither show up well in photos online unfortunately. But if you were to see them both in the flesh you would probably come to a different conclusion, that different effects are at play here and it's not the same root cause.
I've had a good look at a door that was removed for replacement, because of blistering.
Whilst I know the locations of blistering has been shown to vary, and 'can' appear anywhere, by far the most common location seems to be centred around two horizontal rows of blisters that run along the door, a couple of inches below the window seal line, and the second row around two inches below that.
On the inside of the door, is a composite stiffener thats bonded to the inner surface. It has a joggle in it's form, that also plays the role of securing the bottom edge of the rubber window seal.
It's very clear on close inspection that the channel that this forms acts like a tiny gutter, in which water will 'sit'.
It's my opinion that any water that gets past the window seal and runs down the inside of the door skin, and sits in the gutter-like track, seeps into the unsealed inner door skin surface (osmosis style), likely reacts with chemicals within the laminate, and ultimately finds its way out, under the paint, forming blisters.
It appears, by the common dual rows of blisters, that this also happens at the lower edge of the stiffener, with water possibly just being held there via capillary action.
It certainly seems logical that two parallel runs of lingering moisture on the inner (unsealed) surface, presenting as blisters directly adjacent on the outer surface, suggests the blisters are related to the water present on the opposite side of the skin.
I plan to remove the window, regulator, seal etc, and go in with a dremel multifunction tool to grind out small gaps in the upper joggle to form drains, so no water is trapped, and also to seal the inner door skin with 2-pack paint, especially in the upper & lower 'water traps', in an attempt to stop this water ingress into the back face of the composite material. To clarify, I will seal the entire inner surface of the door skin, and address the gutter issue caused by the stiffener.
It will be important to not only remove the gutter trap element (a huge design fault IMHO), but also to ensure satisfactory sealing of the creavis where the stiffener is bonded to the door skin.
If I'm right about this, storing your car in a garage won't help, as the water that accumulates in that trap every time it rains, or you wash your car, is still sitting there, possibly for weeks, trying to find it's way into your door skin via the back (porous) door.... in fact, if you live in a hot, dry climate, there's much better chance of this moisture drying out before it does harm, if left outside in the sun, than indoors.
I don't use a hose, when washing my Emira, or any other method with copious amounts of water. I use a micro-fibre mitt with minimal soapy water (wrung out), wipe the car, wipe again with it rinsed, then leather it, using this method, no water runs down the inside of that door skin.... at least until i've done my mods.
I appreciate I shouldn't have to take this ridiculous precaution, but until I'm sure I've addressed what I believe to be the cause, it's what I will continue to do.
I've drawn a rubbish sketch showing a section of the door skin, and the stiffener, showing how the upper bit is deff a water trap, and the lower bit likely holds water by capillary.
The proper fix would of course be for Lotus (or Tejin) to completely seal the inner door skin surface (actually ALL inner skin surfaces of the composite panels) during manufacture 'BEFORE' bonding the stiffener in place.... Or to develop a less reactive composite laminate. .... But that won't be happening for my Emira, so I guess I'm on my own.
P.S. My Emira is now 2.5 years old, and so far, no blisters at all... but it never goes out the wet (unless I get caught out) and is garaged/pampered.
I suspect you’re correct re the cause, but are you not worried that if you take a dremel to your doors, and the paint blisters anyway, that Lotus will void your paint warranty?
I think this is the best photo I can get and it's actually worse than I last looked and way worse than before it was repaired!
  • Sad
Reactions: VR1
Someone did ask that back at post 200.
My reply was:
"I actually think my dealer would act sympathetically anyway, given the dreadful lotus reaction to these issues. I don't see that they'd have any vested interest in blocking such a warranty claim, just because I 'tried' to improve a dire prognosis. .. It's hardly a secret that there's a major manufacturing problem with these composite components on Emira."
Also, of course, the dealer takes a profit from these warranty repairs, so they're really not likely to dob you in to lotus (and it could only be them that could trigger that). It's a shit show and they know it.
I was speaking to Lotus Silverstone about this. The warranty repairs are not done by the dealer but by an approved body shop. So the dealership makes nothing out of this - it just costs them time and effort to process the warranty for the customer and do the paperwork for Lotus. At least this was my recent experience; I do think this process has been changed by Lotus recently though as Silverstone are no longer using the local bodyshops they used for previous work.
Maybe that's what they told you, but trust me, they do.
...it's not the same root cause.
I don't think anyone is saying it's the same root cause. That's the whole point.
Many keep thinking (and selling to the world) that all of these paint adhesion problems are separate and each have a specific root cause as fact. The reality, Lotus has never (and likely will never) confirm the specific of the root cause.
Given the preceding, I'm of the belief that there are multiple variables in play and some do in fact cross-over. Whether it's the micro bubbling, the few that looked like cheap bondo paint fractures or the most recent large bubbling/paint delamination on the rear bumper near the exhaust, they are all paint failures in some way shape or form and likely (but not proven) to have at least one variable in common.
BTW, by far the best theory specifically to the door micro bubbling is the interior channel collecting water theory that @JonFuller originally proposed. It absolutely makes sense and also supports why the Poll on how the car is stored showed a mild correlation with cars stored outside and how the UK or other "rainy" climates appear to have also a slightly higher correlation with the micro bubbling/blistering.
I was told the same thing by my local dealer. To them handling paint warranty claims is just a monumental pain in the ass, and they see it as Lotus dumping responsibility on them. This dealer had new cars delivered fresh off the transporter from Hethel which already had paint bubbling. And the dealers are just as much in the dark as the rest of us about the root cause or whether the problem has ever been fully resolved in production. Complete shitshow.
...This dealer had new cars delivered fresh off the transporter from Hethel which already had paint bubbling.
I haven't heard of this stateside. If accurate, it really speaks to plant workers being at the point where some have just given up. Sad state, if accurate.
OK good news is that I now have my Emira back from the bodyshop with a new driver's side door.
The bad news is now I need to take the car back in to them in March to have a new passenger side door, both rear quarter panels and the tail gate done. Panel blistering has now appeared on every one of the other Teijin panels - they all need replacing. This was found by the bodyshop after they removed the PPF.
I also have had the PPF taken off the sides and rear of the car, it looks much better without the PPF. I'm guessing the PPF was not done very well as most of the edges of the PPF showed up with grubby lines where dirt was trying to get in.
Also the bodyshop found that both rear quarter panels had already been replaced and likely the tail gate had been too. So in March my Emira will have had 2.5 tailgates, 4 doors and 6 rear quarter panels.
Also a shout-out to The Beaconsfield Workshop who did the work.
Lotus Silverstone took my Emira to Beaconsfield for the door replacement and respray. It seems all/many Emiras are being taken there for this work now by Lotus.
The guys at Beaconsfield Workshop very helpful, kept in touch the whole time and had the repairs done quickly in just a few days. The quality of the work is also really good - the drivers door is as good as new. I had arranged to get the train out to pick the car up today and found there were engineering works so told them I might be there late - so they simply arranged to deliver the car back to me yesterday instead.
I spent a long time talking with Dave the owner of Beaconsfield Workshop on several occasions about the problem - and other very interesting topics. They have a very close relationship with Lotus and they have done this work on 100s of Emiras now (I guess closing in on a thousand now) and his workshop is constantly at capacity (so much so he's having to turn away work on Bentleys and Jags - two other brands they do a lot of work on). I don't want to repeat all he said as I'm not sure what was said to me in confidence but most of what he said backs up a lot of what we have already deduced about the problem on this forum.
We've deduced all sorts of things on this forum. Any chance you could be even slightly more specific?
To reiterate Beachbum's comment below, there have been quite a number of suspicions and theories discussed here as to the origin of the blistering problem and it would be helpful to narrow down the actual cause with any additional gathered intelligence.
My build is Nov 2023 (with full PPF after 3 mos of delivery) and to date, I have yet to find a single paint bubble/blister but it's been difficult to pinpoint the reasons for so many incident inconsistencies. Having stated this, with all the reported cases, one can't help but to live with the uncomfortable anticipation of upcoming bad news. We've done Polls and many members have provided their inputs, but the mystery, at least in my mind, still remains as to the true origin of the issue. Is it caused by the composition of the Teijin panels, the type of paint itself, the undercoat, a bad day at the factory, weather patterns, etc etc? I would have thought that the input of a professional paint shop expert would be very valuable. Thanks
...I don't want to repeat all he said as I'm not sure what was said to me in confidence but most of what he said backs up a lot of what we have already deduced about the problem on this forum.
Agree, no need to repeat anything that was said in a private conversation.
However, if you don't mind, why don't you tell us what your latest "theory" is given your latest first-hand experience with your car and any additional "insight" you've picked from "friends" that have also shared their first-hand experience with you. Inquiring minds would love to know...
