EU/RHD BMS JB4 OBDII Harness Extension
mr.suntorytime
Emira Fondler
⚙️ Supporting Maker ⚙️
My Specs:
Emira V6
EU/RHD Emira owners who ordered a JB4.
OBD2 harness extensions are now available!
Thank you for your patience!
https://www.darkworks-design.com/products/bms-obdii-harness-extension-1-meter
Can you confirm, if you now order a JB4, for a RHD car, you still have to purchase an extension to get it to fit?
Burger motorsports recommends that the JB4 be connected to the OBDII port at all times if you are using any map besides map 0.
To prevent fallen cables from getting caught in the SC/engine belts if cable ties fail, the bracket was designed to be located opposite the SC pulley.
That being said the OBDII harness from BMS is 700mm or so too short to reach the other side of the cabin, so this extension fixes the issue weather you choose to run though the interior grommet or outside the car for diagnostics.
hope this helps!
