Yes. This was with Map 1 and actual 91 octane gas. It looks like some or most of the people posting dynos of Map 1 still have 93 in the tank, which would allow Map 1 to operate right to its limit due to the extra headroom against knocking the 93 would have. I don't have 93 available so I can't do a Map 1 - Map 2 comparison.
The JB4 dyno I got showed what I felt when switching to Map 1; a definite increase in torque at the lower rpms. What it also shows, is that through multiple dyno pulls spread out over a year with several different mods, once the rpms get close to 5k all the lines pretty much join together. That tells me the exhaust is the bottleneck. I believe all the people showing bigger gains have deleted their 3rd cat which would reduce back pressure and allow for more performance. Most people also seem to be using Dynojets while I'm on a hub dyno which are known to be more conservative.
In order to give you some reference data, the dyno showing meow’s +57whp gain was on pump ACN91 with a bottle of Boostane shot — the tiny little bottle. He only has a valve controller no other modifications. Ambient was around 85F and it was on a hub dyno as well. The numbers were similar without and with the boostane shot.
So that's on an otherwise totally stock car? Do you have the dyno chart you can post? I'd like to see how the power curve developed.
Seems like there's some confusion, so compiling it all here (from posts from @sendmeows and @kitkat, I don't have any insider info).
Setup Details:
  • Car Details: valve controller, no other modifications.
  • Ambient temp: around 85 deg
  • Dyno Details: hub dyno, all figures taken same day in same session.
Labeled Dyno Plot:
* Power of green line is approximated by looking at legend. Power of red and peak taken off bottom details
Dyno Figure Legend:
redstock~332HP
greenmap1 + 91~372HP (+40)
lightbluemap1 + "93"~390HP (+58)
greymap2 + "93"~390HP (+58)
* 93 was approximated via 91 fuel + a boostane shot.
Interestingly, it also looks like map1 with 91 octane would have made more power if run all the way to redline like the others....
Setup Details:
Labeled Dyno Plot:
Dyno Figure Legend:
redstock~332HP
thanks for summarizing. the green 372hp line was our first successful run. subsequent runs were to redline at 370 and 368.
Hey guys,
After following this thread closely and finally pulling the trigger on a JB4, I’ve got to say… I’m a bit disappointed with the results.
My car has a 3rd cat delete + Milltek open valve.
A buddy here in Dubai (also on this forum) installed his JB4 before me, so we ran some tests — my car stock (with the mods mentioned above) vs his car with the exact same mods + JB4.
Honestly, the results were underwhelming. From a 40 to 140 pull, the difference was basically 1 m length in his favor… nothing crazy.
Fast forward a few weeks, I installed my own JB4, and… I can’t feel any real difference, apart from whatever my brain wants to believe because of placebo or wishful thinking.
Apparently, in Dubai we don’t have the equivalent of US 93 octane. We’ve got 98 here, which is basically equivalent to 91 for Map 1 — and yeah… no noticeable difference.
To be fair, it’s summer here, and our insane heat probably isn’t helping the car’s performance, but still… I expected to at least see more of a gap between stock and JB4.
P.S.: Why has no one in the US posted any stock vs JB4 race videos yet?
Reactions: TFS
Not many folks get together to do drag or street light races, it's pretty solidly outside the "intended use case" for the Emira.
If there's really strong interest I'm sure it could be arranged, but it's just not a priority.
I suspect your 91 octane equivalent and high temps are really keeping you from enjoying the benefits.
Setup Details:
Labeled Dyno Plot:
Dyno Figure Legend:
redstock~332HP
Thank you for the summary. What surprises me the most is the baseline stock number of 332 hp. My absolutely stock baseline was 369 which I got right after the 1,000 mile break-in. The pull after installing the Eventuri was 386 hp. The last pull a week ago with the JB4 was 391, which is essentially the same as this car with Map 2 and the derived 93.
The baseline run on my car showed 303 lbft of torque, and with all the mods it's never gotten above 318 lbft. However on the above chart that car's baseline which was 300 lbft (basically same as mine), showed a much bigger gain to 335 with the JB4, taking a jump at about 3,800 rpm.
The biggest surprise to me is my car having 37 more hp stock than his. The drivetrain loss on mine (assuming the factory rating of 400 is pretty accurate, 400-369.6) was 7.6%. His (400-332) is 17%. Doesn't look like these engines are SAE rated.
If as many people who get the JB4 can get baseline/JB4 dyno charts and post them here, we'll begin to get an idea of the performance range of the V6. It'll be interesting to see what the average drivetrain loss is. Either mine's a fluke at 7.6%, or the engine was putting out much more than the factory stated 400 hp. If there's a fairly large variance of power output stock, that's going to have an effect on the gains and numbers posted for the JB4.
Hey guys,
Altitude, temperature and humidity will have an effect. Here's a short excerpt on the effect of ambient temperature on engine performance:
"High ambient temperatures can significantly impact engine performance by altering the thermodynamic conditions under which the engine operates. As temperatures rise, the air density decreases, leading to lower oxygen levels in the intake air. This reduction can result in less efficient combustion, affecting power output and overall engine efficiency."
High altitudes and humidity can affect power too. You're almost at sea level but with a high humidity; the average humidity of Dubai is 60%. Humidity in the air reduces the amount of oxygen available for combustion, so the higher the humidity, the less oxygen, the less power. Now combine your very high temperatures and humidity, that's literally the worst conditions for an engine to produce power.
Were you able to view the meters on the JB4 app to see what the IAT was?
