The service manual instructs you to use the jack-up point on the rear side.No center jacking point like the Elise? Ill have to figure something out.
If you don't have a Costco membership, right now the shipping is free from Quickjack to the continental 48 states. The entire package which is 3 boxes weighs 250 lbs., so having it delivered to your house for free is not a bad idea.Costco also sells them at about the same or less. Can't beat Costco's return policy either.
Is this something you would feel comfortable leaving jacked up overnight? I like the idea of this for maintenance, prep, and cleaning.For those interested, Quickjack is having a Labor Day sale (Sept. 1-8) for their Quickjack lifts. I ordered the 5000TLX because I want to also use it for my Alfa and Honda CR-V. The 5000TLX can lift up to 5,000 pounds, and has a lifting spread of 66 inches. My Alfa lift points are 61 inches so the cheaper 3500 wouldn't work because it's maximum lift spread is 60 inches. I don't know what the lift spread is for the Emira, but I doubt it would be more than my Alfa which is a 4 door sports sedan. The 5000TLX lifts to 24 inches which should be plenty of room to do oil changes and such for the Emira.
www.quickjack.com
Use the discount code LABORDAY to get $300 off.
Absolutely, I've kept cars up on mine overnight when I had a project and didn't finish until the next day. The jack is mechanically locked in place and does not rely on the hydraulics to stay raised. I've always tossed a couple of jack stands underneath when I'm under it "just in case", but there have never been any problems.Is this something you would feel comfortable leaving jacked up overnight? I like the idea of this for maintenance, prep, and cleaning.
I currently have an E39 540i that has been on my quickjacks for at least 3 months (while I slow-roll a cooling system upgrade). 100% confident in the design, and when I'm really wrenching on something underneath I'll will also put some shoring (wood or other jacks) just below subframes for that extra feel-good factor.Absolutely, I've kept cars up on mine overnight when I had a project and didn't finish until the next day. The jack is mechanically locked in place and does not rely on the hydraulics to stay raised. I've always tossed a couple of jack stands underneath when I'm under it "just in case", but there have never been any problems.
You wouldn’t want to use them this way anyways, they’re offset.The distance between the front and rear jack-up points of the Emira is about 1900mm.
Perhaps the 5000TLX is not long enough.
The quick jack has a crossmember adapter option, but it's not long enough, which means I can't use it.You wouldn’t want to use them this way anyways, they’re offset.
can i respectfully suggest you skip back a page and see my emira up on quick Jacks.The quick jack has a crossmember adapter option, but it's not long enough, which means I can't use it.
Still, I don't know how to use the rigid jack.
Is this the 5000 under your Emira?Used it on Esprit Exige and now Emira but only transversely.
The staggered arrangement of the jacking points make their use a tad challenging until you 'find a way'.
See the use of a small length of timber and a hockey puck on the NSF jacking point.....
yesIs this the 5000 under your Emira?
This highlights the source of my question... I totally get that Lotus has specified the point loading locations where the car should be lifted using a point-support jacking system like a 2 post lift.
BUT... is it an exclusive/explicit requirement? Is it ok to lift the car "flat" as long as those specified locations are fully supported?
See here: Seems like a platform jack like a QuickJack or one of the full size BendPak split platform scissor lifts would be able to engage the entire bottom of the car along the frame rails, if someone wanted. Talking about lifting by the full length of the angled sections of the center chassis, like so:
Using something like this:
They come with lifting blocks as well (see below), though it would be a touch more challenging with the odd inboard spacing on the Emira because I think it's right at the limit of where a platform would extend to if installed "standard". That's why I'm asking about a full-frame-support approach.
I've been thinking about this a lot too. Especially since you can make up custom rubber pads, as big as you like, to spread the load along the rails. I have the larger 7000TLX and don't know if anyone has confirmed that it will fit between the wheels and body sills. I should be able to test in 4-6-20 weeks (CARB depending).We recently had a discussion with Greg (GRP) on the Lotus Discord about how he uses his Quickjacks on the Evora and he uses them along the frame rails safely and not just on the designated lift points. If this is fine, this opens up plenty of options for using the shorter Quickjacks along the sides of the parallel framerails.
Yeah I'd imagine the 700TLX would hit the wheels -- will wait till Greg tests on the Emira with the shorter 5000 series and I'll snap one of those up with extensions for cars with longer jackpoint distances.I've been thinking about this a lot too. Especially since you can make up custom rubber pads, as big as you like, to spread the load along the rails. I have the larger 7000TLX and don't know if anyone has confirmed that it will fit between the wheels and body sills. I should be able to test in 4-6-20 weeks (CARB depending).
I'm considering doing a mid-rise lift but it has essentially the same kind of constraints and scenarios.Yeah I'd imagine the 700TLX would hit the wheels -- will wait till Greg tests on the Emira with the shorter 5000 series and I'll snap one of those up with extensions for cars with longer jackpoint distances.
what engine upgrade would make the emira quick? | Lotus Emira Modifications | 14 | ||
Emira Forum Zoom Call - Sunday, May 19 | Lotus Emira Events | 5 | ||
GRP Customized Emira Steering Wheels! | GregsRaceParts.com | 10 |
