DIY: V6 Burger Motorsports JB4 Installation
kitkat
Emira Chaos Monkey
Emira of the Month 🏆
Time for another Emira V6 DIY, this time it's for the Burger Motorsports JB4!
Installation Overview
Instructions
This installation assumes you are using a Darkworks Design JB4 Stealth Bracket. If you aren't, please skip steps 3-7 and figure out a way to zip tie your JB4.
1. Optional: Install Mobile Wireless Smart Phone Kit to your JB4 if you purchased it.
  • 4 x H2.5 on the case
  • Discard the extra small rubber plug
  • 2 x phillips head screws that come with JB4 Mobile Kit
2. Remove front top engine cover
3. Remove rear top engine cover
4. Remove left side (LHD) engine side trim
  • 4 x H4 button top screws
  • Extreme Caution: Do not drop
5. Remove OEM air vent bolts
  • 2 x 7mm 6 pt drive bolts
6. Attach JB4 Bracket to the vent bracket
  • 2 x 8mm 6 pt drive bolts that come with JB4 Stealth Bracket
  • This is probably the hardest part of this whole procedure
7. Attach JB4 to JB4 Bracket
  • 2 x H3 button top screws that come with JB4 Stealth Bracket
8. Optional: Wedge your Mobile Wireless extension between the firewall and the felt cover
9. Route your cables as per the video or however you see fit
  • Don't touch the heatshield or the valve cover those get too hot with your wiring harness
10. Unclip MAF and TMAF sensors
11. Plug in the JB4 Connectors into your MAF and TMAF sensors
12. Tie down and affix your wiring harness
  • I used 3 sticky 3/4" zip tie bases and 3 zip ties to affix the wiring harness to the outside of the engine bay box, the engine cover hides all the wiring once in place
13. Reinstall left side (LHD) engine side trim
14. Reinstall rear top engine cover
15. Reinstall front top engine cover
Did you install the OBDII cable, or just go with it as-is?
I have to figure out the OBD2 cable, I'll be removing the rubber blank plug on the firewall and printing out a new one out of TPU. I have an idea of what it will look like but I still have to pull it out and take measurements. It's a problem because I think my carbon buckets might have to be removed on the driver side to get at it.
Thanks for the video. Looks too straightforward to be true - what's the catch? How many screws did you drop? ;)
Let's just say if you drop a screw or a tool, your installation time goes up by the amount of time it takes you to jack the car up and remove all the underpanels and put them back on.
That's _if_ you find them at all.
These are the two essential tools every mechanic needs:
This one is magnetic for screws, nuts, bolts, etc.
This one has a retractable claw for everything else.
What about just slicing the stock one with a razor?
Is that wireless kit only used to connect the JB4 to the phone App?
If you purchase the wireless connectivity kit, do you still need to install the OBD2 cable to access that real time feed?
If so, it would be nice if there was a Bluetooth dongle that could connect the JB4 to the Emira OBD2 port.
You don’t have to install the OBD2 cable at all if you don’t want to but you need it if you plan on sending logs back to Burger to fine tune things or check your fueling quality.
Reading OBD over BT ELM would be nice but I think they’d need a new board for this and probably move over to something more expensive. The overwhelming majority of people here won’t need to do the OBD install and I haven’t figured out solid instructions so I didn’t supply those instructions. I’ll update my first post once I figure all that out.
We cannot do proper data log without the obd2 cable connected ?
Correct, the JB4 unit needs access to CAN which it does not do with those two connectors to the map and tmap sensors.
So to change the maps one also has to purchase a Windows laptop or cell phone? There’s no physical way on the unit itself to change the maps?
Who dont have a cell phone these days ?
Especially if someone is into / looking for tuning and dont already own a laptop or a cell phone it would be pretty surprising.
Correct!
Thanks KitKat. My understanding (could be wrong) is that if you have the OBD2 connection installed that the system would/could automatically adjust the tune in real time which I think would be a cool feature. From what you say, you would need to send logs back to Burger for them to make adjustments to the tune? If that is the way it works, do they fine tune it for individual tunes, or do they make updates to the software in general foe everyone to access?
A few people have sent in their logs already and Burger just okays them to say nothing needs to be changed. I think they’re just checking for safety. As for OBD2, not even Burger is guaranteeing the OBD2 for sure will improve anything I think that’s just their standard language.
@kitkat Correct me if I'm mistaken, the tuner doesn't seem to offer any benefit in power or torque until you cross roughly 5300 RPM on the V6?
I’m not sure how you’re interpreting this — but even at 2,500 rpm there’s a 25 ft lbs difference in torque.
Well your affirmation is partially true in regard to the map1 on 91 octane gas.
The torque is a bit better at lower RPM like kitkat said but the major gain is between 5K and 6.8K. So the map1 is going to feel similar for cruising around but at wide open throttle the difference should be noticeable. My guess is that if you run the map1 with 93-95 octane it should be even better.
Now in regard to the map2, the gain are noticeable at every RPM but especially from 3 800RPM and higher.
If we could get a 7200rpm limit we could stay into the best powerband for longer period of time and it would be very beneficial.
