Problem solved:
CHECK ENGINE LIGHT IS ILLUMINATED, VEHICLE WENT INTO LIMP MODE
Part # 9 A 7 - 1 3 3 - 2 4 6 - A EMIRA MUFFLER ACTUATOR MOTOR
Part # CE4503 ELECTRICAL CONNECTOR
CHECK FUSE, BLOWN, PUT NEW FUSE BLEW ALSO, REMOVE ENGINE COVER AND
FOUND ACTUATOR MELTED. REMOVE AND ATTEMPT TO INSTALL USED, NOT WORKING.
REINSTALL PARTS. LEFT ACTUATOR DISCONNECTED. THIS WILL CAUSE A CHECK
ENGINE LIGHT, BUT VEHICLE SHOULD NOT GO INTO LIMP MODE. PERFORMED
EXTENDED ROAD TEST. CEL RETURNED AND VEHICLE WENT INTO LIMP MODE.
SUGGEST REPLACING ACTUATOR AND APPLY HEAT SHIELDING TO EXHAUST SYSTEM
AND VALVE CONTROLLER. NOTE: AFTERMARKET REAR DIFFUSER DOES NOT HAVE
VENTING FOR EXHAUST AND ACTUATOR. SOURCED REPLACEMENT MUFFLER VALVE
ACTUATOR. FOUND ELECTRICAL CONNECTOR AT VEHICLE WIRING HARNESS ALSO
MELTED. SOURCED REPLACEMENT HARNESS CONNECTOR. SPLICED- IN NEW
CONNECTOR. SECURED TO NEW ACTUATOR. STARTED ENGINE AND CHECK FOR
FAULTS. FAULT STILL PRESENT FOR ACTUATOR. FOUND ACTUATOR WILL NOT
"PARK" UNLESS CONNECTED TO MUFFLER VALVE. SOURCED MUFFLER VALVE.
FABRICATED BRACKET TO SECURE VALVE TO CHASSIS. INSTALLED ACTUATOR.
TESTED. FAULT DOES NOT RETURN.
