Exhaust System Upgrade Options Available for Turbo I4 AMG Engine Yet?
Is that how you got it out? Did you have to cut or trim that access panel? Inquiring minds want to know.
You see the heat shield being bent up.... A quick fix but yes. It comes out that way. The trick is that bracket with the little pin on the RH side.
Edit: the second trick: remove the bracket on the bottom with the two 10mm bolts plus the 18mm. Need all the space you can get
My exhaust from Mach5 is finally in the final stages of shipping. They sent me instructions on their valve controller and it gives a clearer picture of what “remote” valve controller means. I guess this way if the valve controller on your exhaust dies, the car won’t go into limp mode? Dunno
