Emira track impressions
Sway bars transfer some amount of compression from one side to the other. I retained the OEM sway bar.
The suspension now compresses less when cornering, so it moves the sway bar less, and the higher spring rate on the other side resists sway bar rotation more as well, so on net, relative to compression, I have reduced the influence of the sway bar, since its torsional rigidity, as a percentage of suspension stiffness, decreased.
The car felt perfectly nice on the track without changing it, and I don't mind body roll. My Elise had no sway bar in rear at all, a truly independent suspension. It leaned like the Tower of Pisa in turns, but it gripped great, and I just care about grip.
To music or not to music?
By default I don't play music on the track. But you know what? it sounds like fun. We have to run with windows open though so you can't really hear anything anyways 🤣
Not here to rain on anyone's parade but playing loud music in the car on track has a few down sides to consider (which you may have already decided it's ok for you); it doesn't let you hear the tires as much so you're lacking one sensory input on how they're performing at or beyond the limits of grip, you're less likely to hear mechanical noises that could be a sign of a problem, and similarly you are losing a potential input of hearing another car closing in fast and perhaps they're not following your run group rules of point by or they have some sort of issue (skill issue or mechanical) that you might be able to avoid a collision with if you missed visual cues.
True. I don't run music much though. But that set I did. I ran one of my better laps, even with needing to pass. The music isn't that loud. I can hear everything. It does brig to the next level. Plus, the song is Red Barchetta - about racing a car. Lol!
Tire wear is a huge compromise of a lot of factors. If you're still chewing at the edges but don't want to spend the money on hardware, you have a few options - change how you corner, change your tire pressures, and manage temperatures throughout a session.
Would you say more tire pressure to reduce side wear? These are the goodyears.
Red Barchetta is also about someone driving a racing car illegally when driving is banned. Bad omen :) Rush is awesome, tho.
It does look like your tires were mildly under-inflated, yes.
Interesting. The pro coach wanted them much less than I had them. I start at 26/29. They heat to 35-38. They had them heating to 33-34.
My buddy did this the Emira was "so sticky" even with endurance 200 TW tires.
Yes. In lieu of enough camber, tire wall stiffness, and roll stiffness, the two variables you can adjust for free are: tire pressure and your driving. Will you sacrifice lap times and grip? yep, it's all a compromise. Once you start to better understand more cause and effects, I think it begins to make a lot more sense.
Your coach also isn't paying for your consumables/tires. So yes lowering them - to a point - will likely give you some additional grip - but these are street tires, not track tires - so driving the piss out of them will lead to excessive and premature wear.
It looks like they rolled over too much. I set my tire pressures with the help of a probe pyrometer and they rolled over less than yours. i can snap a picture later, as the scrub is still obvious. A pyrometer makes it obvious. Linear temperature gradient on tire = correct pressure. For me, this was very close to 35 PSI hot in all 4 tires. So, you weren't very far off, but you could have driven differently than me, on a different temperature day, etc. At these pressures, my temperatures were in the 160F range in the rear, and 130F range in the front.
Just to clarify, that picture was the OEM GY tires. Those lasted 2.5 days. The Continentals lasted much longer. With much more aggressive driving.
For what it's worth, this is the pro. Before letting air out. On the Continentals. With Aggressive pads and lighter front rotors. Same setup I had on the above video. 10 seconds faster. Crazy how much better he is without even trying IMO.
I would like to use my Track addict app to record like this when I track next week to get some videos for the forum of New Jersey motorsports park and
the New York safety track. Which Inside windsheild phone mount dd you use?
Any other good recommendations from anyone esle?
Goodyear Eagle F1's on the track feel like running on stilts. I have Touring suspensio0n which is a bit of a let down but for a stock car its certainly reasonable however. My local track I went to once and was doing around 1'33. Only changed to Continental Sportcontact 7's and find i was in the 1'27. Big improvment. Of course now its a slippery slope of , I need suspension, need brakes, then need more grip, then more power etc. Im sure most of us here have been down that road. Big difference coming out of a Dallara F306 and a Radical Prosport. I really should just get another race car. But I do love the Emira and its alright on track for a stock really.
I found 36-38 hot was a good range/ Also I was seeing 1.7 and once 1.8G on the dash as well.
This is the one I use.
Then this gets you throttle and boost info from the car
Track Addict let's you choose what to display on the video when you "render" it from the app to your phone. The gears are sometimes weird for a manual. It was displaying one gear too low. There was an option to add +1, +2, etc. I choose +1. Sometimes it's right. Sometimes it's one gear too high. The throttle isn't perfect either. Those long straights are WOT for sure but the app displays 90% range. But it's pretty good. Catalyst doesn't have any throttle or ability to get a bluetooth connection. But it has better speed accuracy.
Good luck!
