Tracked Emira
The picture shows the New ZL1 Addons tow hook mount from www.gregsraceparts.com
Please do mind the gravel…Finally got to an acceptable level. Shaved off maybe 0.38mm. Sort of wish I left it at 0.37mm, but good enough.
Simple solution for meIt depends on your camera type. I just received mine today, for a GoPro 13 camera, which has a different set-up:
For those interested and in case it’s helpful:
1. You need long nose pliers to pull the “plug” blocking the threads for the tow hook (photos below shows the “plug” on right, recessed behind the bumper, and what it looks like removed).
View attachment 59646View attachment 59647
2. The tow hook threads in, COUNTER-CLOCKWISE. Once tightened, mine was straight (parallel to ground). Those unlucky enough to tighten crooked, I suspect received a defective one with improper threads and should return it (?).
3. I used a 3/8” hex bit or Allen socket, to remove the OEM ZL1 tow hook bolt.
4. To replace it with the bolt from the camera mount kit, you re-use the 2 OEM white plastic washers.
5. For a GoPro camera mount kit, before inserting the new bolt, you put the bracket the camera attaches to, on first. Then you put the small silver sleeve from the kit, to sandwich the bracket between the sleeve and bolt head. Then install with same 3/8” socket. Putting a cloth on the ratchet handle is a good idea, to avoid scraping body paint with the ratchet.
6. My camera mount when level, touched the bumper. So I installed it at an angle to leave a gap, then angled the camera up, until it was level. The camera mount adjustment nut, was 11 mm (7/16”).
Now I’ll carry long-nose pliers as part of my stock “car tool kit”, should I ever need to use the tow hook (the OEM trunk kit includes a regular tow hook). For my “track kit”, I’ll take the ZR1 tow hook, camera and mount kit, a 3/8” rachet, 3/8” Allen socket, and 11 mm wrench.
Did you have someone trim the exceeding material with a lathe? or did you shave it off yourself with a file?Finally got to an acceptable level. Shaved off maybe 0.38mm. Sort of wish I left it at 0.37mm, but good enough.
I had it turned on a lathe at the motorcycle customization shop that does work for my bike. It was a trial and error process, shaving off tiny bits at a time.Did you have someone trim the exceeding material with a lathe? or did you shave it off yourself with a file?
I've received my tow hook and it looks exactly as yours, 1/8 of a turn less. I need it parallel to the ground in order to mount the action camera.
I feared so. I also have the issue of having to attach the camera mount flush, and the oem bolt is not long enough. Not living in the USA, it will be a paint to find a longer bolt of the same thread/size, including the thickness of a spacer which wasn’t included as well. Wrong thread on hook, no spacer, no replacement bolt. I must say that this camera mount pack is really not well thought.I had it turned on a lathe at the motorcycle customization shop that does work for my bike. It was a trial and error process, shaving off tiny bits at a time.
I understand the issue with the thread not ending at the "correct" point, but what do you mean by the spacer and replacement bolt? They should have been included in the camera mount kit.Wrong thread on hook, no spacer, no replacement bolt. I must say that this camera mount pack is really not well thought.
Nope, nothing except the black 90° piece and the action cam mount. No spacer, no bolt.I understand the issue with the thread not ending at the "correct" point, but what do you mean by the spacer and replacement bolt? They should have been included in the camera mount kit.
That does not sound right. My kit included the black 90 degree angle with action cam mount, aluminum spacer, and longer bolt. I did not need to source any parts on my own.Nope, nothing except the black 90° piece and the action cam mount. No spacer, no bolt.
I got it from GRP. I'll try to reach them out.That does not sound right. My kit included the black 90 degree angle with action cam mount, aluminum spacer, and longer bolt. I did not need to source any parts on my own.
You should contact whoever you bought it from.
