Hey All,
After spending some time searching existing posts for the following info, I'm hoping the moderators would consider pinning a 'sticky' topic within the "Supercharged 3.5L" forum category that gathers detailed specs and references for the V6 supercharger.
"It's an Eaton R1740 compressor section in an Edelbrock housing made specifically for Lotus. The R1740 is a roots style with 4 lobes, 160deg twist." (Thanks @Porter)
Eaton TVS R1740
Main Eaton TVS Page
- Although some folks have also referenced "1750" when quoting from Emira promotional material...?
Here is a video showing assembly of what appears to be a similar (probably non-Lotus spec) Eaton/Intercooled unit from Edelbrock.
- Nice to see how the intercoolers fit in (similar to Audi 3.0L setup).
- Also nice to see where the bypass valve is, and maybe (just maybe), people will stop calling the bypass valve actuator the "throttle linkage"
Assembling an Edelbrock Supercharger
Edelbrock housing part number or kit number (for parts reference)?
Is this Edelbrock kit identical to an Evora implementation?
- If so, which Evora(s)?
Any Evora-based DIY links for upper cover or entire SC removal/reinstallation?
B&C supercharge parts catalogue
(Thanks @Rudi)
Thread for Painting the supercharger cover
Part numbers for cover and gasket: (thanks @Time2Fly )
Cover 8891348489
Gasket A132E0169F
Upper cover bolt type?
- Torque specs for the cover bolts should be 10nM (thanks @VL3X)
Gasket/seal part number for housing to manifold?
Housing-to-manifold :
"Supercharger to intake manifold is 10Nm
It all starts on page 42-15 of the service manual." (Thanks @Time2Fly )
- bolt type or p/n?
Supercharger Oil specification?
Eaton/Edelbrock/Lotus recommended oil change interval?
Oil plug part number?
- torque spec?
Is this unit vacuum or electrically controled for the bypass valve?
- I'm guessing vacuum, since the actuator appears to have a chamber (bean pot) similar to the Edelbrock assembly video above
Is there a position sensor on the bypass valve? If so, is there a code reader / diagnostic tool that allows viewing or logging of the bypass valve position?
Stock pulley sizes?
Stock SC belt part number?
More supercharger stuff, just for fun:
Engineering Explained - Supercharger Type Comparison
Eaton TVS animation with a very different bypass and intercooler setup
FCP Euro SC oil change on an Eaton
Motor1 Article with some history: Rise and Fall of the Supercharger
I'll continue searching and updating as I find details, but please post any replies with specs and references if you have them on-hand, and I will incorporate the data in the main post.
Eaton TVS R1740
Main Eaton TVS Page
(Thanks @Rudi)
Cover 8891348489
Gasket A132E0169F
- bolt type or p/n?
- torque spec?
Stock pulley sizes?
