US I4 (400hp) has fake engine noise pumped through speakers
Hello, you say in your post green wire with a yellow stripe. But on the pic and on my car, it looks like a green with blue stripe ?
That green wire is alone with the grey/white/purple wires. They are 2 other green wires but they are in pair in thermal/plastic sheath.
its green with blue stripe
Job done. Night and day différence ! I have done a track day and that fake noise was so annoying. Everything sounded fake from throttle to gear changes. I would be pissed if I bought a downpipe or an exhaust at xxxx€/$ just to mainly hear that fake noise…
Sorry about that, yeah it’s the green with blue stripe. My eyes are horrible. I couldn’t see the blue until I zoomed in on the pic.
I cut this wire for a friend today and wow it actually makes the i4 emira sound bearable. The active sound design is so bad!
Thanks for putting in the Magnetic paddles and cutting the wire. I was wandering why I can't ever get the i4 KEF sound to match the V6 using the same setting and source material. Didn't know that the fake engine sound input was messing up the whole system.
So I think cutting this wire disabled the sub. The ASD is gone but the sub doesn’t seem to be firing.
Anyone else experiencing this?
Not for me. My KEF audio is bone stock, sans the wire being cut.
Did you re-connect the harness to the amp after cutting that one wire?
And you did the lone green wire with blue stripe?
Correct, that's only thing I snipped and added quick connectors to should I need it later. BTW, multiple people have done this. I'm wondering if something else got snipped by accident or a plug-in harness came loose while you were in there?
I’ll have to check that I guess fairly sure it didn’t though.
Just an idea for someone: might be able to make a couple bucks making a connector that is inline with the wiring harness that does not include this wire. Some may be hesitant to cut a wire in a wiring harness regardless, and it would be able to go back to stock without a quick connector
Yea, after depinning it. Put some heat shrink over the pin, so no chance of it shorting out on something.
We should put a switch on it next time you have time and then we can do A/B test without the engine running and see if it does cut out the sub signal.
OK, I switched from the i4 back to the V6 today (1st time since having the wire cut). The sub on the i4 are just gone by comparison with the same track at the same audio setting, you can tell even by the air compression at higher volume. Will open the panel up and check and make sure everything was seated correctly.
