US I4 (400hp) has fake engine noise pumped through speakers
Hello, you say in your post green wire with a yellow stripe. But on the pic and on my car, it looks like a green with blue stripe ?
That green wire is alone with the grey/white/purple wires. They are 2 other green wires but they are in pair in thermal/plastic sheath.
its green with blue stripe
Job done. Night and day différence ! I have done a track day and that fake noise was so annoying. Everything sounded fake from throttle to gear changes. I would be pissed if I bought a downpipe or an exhaust at xxxx€/$ just to mainly hear that fake noise…
Sorry about that, yeah it’s the green with blue stripe. My eyes are horrible. I couldn’t see the blue until I zoomed in on the pic.
I cut this wire for a friend today and wow it actually makes the i4 emira sound bearable. The active sound design is so bad!
Thanks for putting in the Magnetic paddles and cutting the wire. I was wandering why I can't ever get the i4 KEF sound to match the V6 using the same setting and source material. Didn't know that the fake engine sound input was messing up the whole system.
So I think cutting this wire disabled the sub. The ASD is gone but the sub doesn’t seem to be firing.
Anyone else experiencing this?
Did you re-connect the harness to the amp after cutting that one wire?
And you did the lone green wire with blue stripe?
Correct, that's only thing I snipped and added quick connectors to should I need it later. BTW, multiple people have done this. I'm wondering if something else got snipped by accident or a plug-in harness came loose while you were in there?
I’ll have to check that I guess fairly sure it didn’t though.
