Transmission Mount Bushing Insert Kit
lllnavarrolll
Hello does anyone have any experience with
Powerflex Transmission Mount Bushing Inserts? If so what color did you go with Yellow or Black?​
Yellow
Haven't noticed any increase in NVH
Gear shift feels smoother, engine rocks less
Mine is a V6 manual, 90% road use
Did you install them yourself? I took a peek back there and it looks like the rear trunk box has to come out for one to get to the rear transmission bracket?
Front bracket looked even more difficult since the bolts look like they interefere with other sub components?
No, had them done at the same time as my 3rd cat delete by my local independent
They said one of them was a real pain!
Yellow
If you could go back in time, would you install the black ones instead of the yellow ones?
Pretty happy with the yellow ones
I'd be curious about the black ones but like the fact there is no extra NVH, don't think I'd want to risk that with the black version
Really wish someone here had a DiY on these.
So there's an earlier thread on these and interestingly someone posted that Powerflex was working with Lotus on a new design. The 2026 notes include revised transmission mounts to improve shifting. I think there is likely some real benefit here if Lotus themselves have taken these folks advice. I'm sure the revised Lotus part will be the whole mount so these inserts seem like a good compromise to get some of that benefit. Id like to see how involved getting to the rear mount is though.
EDIT: Heres the prior thread https://www.emiraforum.com/threads/emira-engine-gearbox-mounts-upgrade.3278/
Good to hear no nvh. I wonder if that holds up over time.
The install is not insignificant. We have an Emira here with the rear clam off and even then, it is a time consuming job. How many hours were charged to those of you who paid a shop to do the work?
Damn, I was afraid of that. How much more work after the rear clam is off?
In the other thread EFE said it took him about 4 hours to do himself. HellasF1 had a shop do it and they charged him 2 hours.
