What specifically are these upgrades?
RyanGphoto
"further optimization of the cooling and transmission. " - Think this might be a better intercooler? How would they optimize the transmission?
" including the introduction of a new compression mount for the manual gearbox, resulting in more precise gear changes." - DO we think this is something like the powerflex manual trans mounts?
"Also, optimised damper calibration and subtle adjustments in wheel alignment provide sharper handling and increased ride comfort." - What do you guys think this is?
I love my car, but do we think these things are available to us existing owners? I know right now I am not doing the powerflex mounts as I read somewhere that it's a 6+ hour job to just install the powerflex mounts.
Lastly, Do you think it's possible to get the safety features of the drivers pack on the car at this point, considering I already have a 2024 Emira?
Any thoughts?
Ryan G
I used AI assistant to compile the table below. Seems like just new coolant piping, new transmission mount, plus new damper settings and alignment?
Feature2024 Emira V62026 Emira V6 SE
Engine3.5L supercharged V6 (400 hp, 310 lb-ft)motortrend.comSame 3.5L supercharged V6 (400 hp, 310 lb-ft)cars.com
Transmission6-speed manual (opt. 6A auto)6-speed manual (new mount); 6A auto (recalibrated)cars.comcarthrottle.com
0–60 mph≈4.3 s (manual)≈4.3 s (manual)carthrottle.com
SuspensionOriginal damping tuneRevised damper calibration, wheel alignmentcars.comcarthrottle.com
DifferentialTorsen LSD (optional on V6)Torsen LSD (standard on V6 SE manual)
Cooling SystemConventional routingRerouted piping for better flow & reduced weightmotor1.com
Exterior Colors(e.g.) Spectre Grey, Eclipse Yellow, etc.Plus Eos Green, Purple Haze (new)motor1.com
PackagesBlack Pack extra, no Racing LineExtended Black Pack std (red calipers, black trim); optional Racing Line with pinstripecars.comcarthrottle.com
InteriorLeather/Alcantara mixAlcantara sport seats standard; 7 theme optionsnews.dupontregistry.comcarthrottle.com
Infotainment10.2″ touchscreen, CarPlay/Android AutoSame hardware; improved software/voice recognition
Driver AidsAEB, LDW optionalAEB, blind-spot, TSR, etc. standard; new ACC & co-pilot packmotortrend.comcarthrottle.com
Price (Base)~$107,500 (First Ed.)carthrottle.com$112,900motor1.com (Race Line +$3k)
🔧 New Transmission Compression Mount​
  • Lotus added a new gearbox compression mount to the manual transmission system in the 2026 Emira V6 SE.
  • This upgrade:
    • Reduces drivetrain movement during aggressive driving or high-load shifts.
    • Improves shift precision, giving the manual gearbox a tighter, more mechanical feel.
    • Reduces shift lever play, which enhances driver confidence during spirited driving.
  • The improvement is especially targeted at track-day or performance-focused drivers who noticed a bit of slop or flex in the earlier V6 manuals under load.
  • This upgrade:
Thank you for this.
Transmission optimization. This section seems to refer primarily to improving the feel of the manual transmission rather than changing the transmission or gears. Hence the mention of the new compression mount.
