Did you install them yourself? I took a peek back there and it looks like the rear trunk box has to come out for one to get to the rear transmission bracket?Yellow
Haven't noticed any increase in NVH
Gear shift feels smoother, engine rocks less
Mine is a V6 manual, 90% road use
No, had them done at the same time as my 3rd cat delete by my local independentDid you install them yourself? I took a peek back there and it looks like the rear trunk box has to come out for one to get to the rear transmission bracket?
Front bracket looked even more difficult since the bolts look like they interefere with other sub components?
Same here. Except for a bit more track use. Install is complex - done by my dealerYellow
If you could go back, would you get the black ones?Same here. Except for a bit more track use. Install is complex - done by my dealer
If you could go back in time, would you install the black ones instead of the yellow ones?Yellow
Pretty happy with the yellow onesIf you could go back in time, would you install the black ones instead of the yellow ones?
Black! Highly recommend no NVH!Hello does anyone have any experience with
Powerflex Transmission Mount Bushing Inserts? If so what color did you go with Yellow or Black?
Not sure I can answer this as I wouldn't know what the black ones feel like and if the NVH would be too much for long distance drivingIf you could go back, would you get the black ones?
