Looking for those that track their Emiras frequently…..
I’m having brake issues that aren’t fully making sense to me. This happened with the factory pads for the initial shake down, and now the EBC RP-1s. I’ve read every brake thread I can find with no definitive answers.
Essentially, I can get about 3 great laps where everything feels exactly as expected. By the 4th lap, the brakes go from consistent and smooth to, inconsistent and “chunky” almost as if they are pulsing, or the pad material themselves are experiencing degradation and build up, but I would say it’s definitively not an ABS issue.
I’m currently running the factory Cup2s and have Motul 660 fluid already installed as well.
1. Due to it consistently happening within 4 laps, it sounds like a heat soak issue, but the brakes never get soft or mushy.
2. Based on number 1, it then leads me to think about heat based warping of the rotors and/or I read a thread about the parking brake getting involved once hot. If that were the case you would feel this all of the time after that initial saturation I think.
3. If it were air in the line, this would create a similar outcome to number 1 with a feeling of inconsistent pressure or mushy pedal, not the feeling I’m experiencing.
4. I could install brake ducting (and probably will), but I still think I would experience a brake “fade” issue rather than the feeling I’m getting when hot.
I was hoping I had a few loose lug nuts or caliper bolts that were allowing too much “flex” and a simple bolt check would solve the problem, but that has not proven to be the case.
Multiple people drove my car and felt the same sensation regardless of their pace. It was always on the 3rd or 4th lap. Each driver is very experienced in tracking and racing. One even owns a shop.
Is anyone else experiencing this? If so, how did you fix it? My next steps are trying a different set of pads and rotors while adding ducting, but that seems like an expensive game of chase, and I believe I read that at least two others had similar issues. Any help you can provide before I go down the economic rabbit hole would be helpful.
Thank you!
Thank you!
