emiraspain
Emira Addict
yes but still quite funny I thoughtIt's the address of the Hethel factory, which may explain a few things?
That must be Harry´s driving searching for fertilizer for his farm!He was right though!!!! Clearly they had been smoking something...
The devil is in the detail..... haha
They may well have interpreted it to mean that your car should stay to the right of the fuel pump? Let's hope notBUT at least they got this right!
Bonus points to anyone who knows what the little arrow besides the fuel bowser icon means!
i guess the same reason your GTi goes to 180 mph..... supposing it wouldnt ever make it no?Why does the track mode tach need to rev to 9k anyway when the car redlines at 6800. 🙄
I think maybe something like that...Could it be that this weird numbering is an effort to smooth out the revs so the bar moves across at a pretty much constant speed? 🤔
The arrow typically points to the side of the vehicle where the gas filler portal is located.BUT at least they got this right!
'We're turning this dial all the way up to 11.'Why does the track mode tach need to rev to 9k anyway when the car redlines at 6800. 🙄
Fuel gauge and temperature gauge is a mirror image of each other. The white bar indicate “units” and empty is black. Strange convention, but I see what they are trying to do. As for tach, I think they are trying to make the rev band to “slow down” during 4k-7k, so it dances about less in the power band?Why does the track mode tach need to rev to 9k anyway when the car redlines at 6800. 🙄
I have an EV that charges at the front. There is no arrow. If one don’t know where your charge port is, then one shouldn’t drive.The arrow typically points to the side of the vehicle where the gas filler portal is located.
However rumor has it that this may be opposite below the equator for the Southern hemisphere.
God knows what it would look like for an EV.
It's a soft limiter when the clutch pedal is not pressed.The thing that baffles me most (besides the 6, 7, 9 derp) in that this image implies 4000 RPM is the redline... The 4K mark can't possibly be a shift marker, that is way too low. What is this trying to convey? Why is it not a different colour (yellow) from 4000 to the actual redline? Why must they constantly mess with us?! 🤷♂️
Ah, ok... I guess that makes sense. Not sure I see the value in that, but at least it explains it.It's a soft limiter when the clutch pedal is not pressed.
How is it no one at the factory or any of the decision makers at Lotus are pointing this stuff out? How did all this get approved and past R&D?Poor design, simple as that 🫤
❓ QUESTION Does it rev match? | Lotus Emira Questions | 9 | ||
Rev Hang in Manual Transmission | Lotus Emira Engine - Supercharged 3.5l | 28 | ||
B | ❓ QUESTION Soft Rev Limiter??? | Lotus Emira Questions | 6 |
