Power reduced to 4k at track need help!!!
Couldn’t connect the VEEPAK OND2 to my Bluetooth to collect data wirelessly.
Tried shutting down phone also. Any one else have an issue? 2 bars on my phone signal
ask someone for wired obd reader at the track. the event coordinators will help.
Did you have all the exhaust mods done at the same time by the same place? I would contact them in the first instance.
Fuse #15 under the carpet passenger i think.
Yes, they couldn’t clear the O2 sensor code .
They said drive it and come back.
The other code is new today that made car not rev past 4k
The fuses were all good.
I guess I have to check the valve controller.
What have you guys done to clear the oxygen sensors. 1 comes on right away and the other oxygen sensor code when I drive. What is the fix to clear and make sure they don’t come back?
I got the VEEPAK connect to read what’s going on, But the o2 sensor output is flat there is no info coming out
Damn it sounds like they got fried. Due to the exhaust? I’d teach to Greg from GRP to see if he was any idea what might have gone wrong. Those o2 sensors are a pretty penny too
