Windshield Washers INOP
freeheelbille
I was in to get the driver's rear tail light replaced the other day. All went fine, but now I'm nearly 4 hours from home, and the windshield washer pump is INOP. Wipers are working as intended, but the pump does not make any noise, like it's trying to pump. The fluid is full.
Is this a shard fuse with the wipers? Could this in some way be associated with the tail light repair? Does anyone know where that fuse is located?
Super annoyed...taillight, power steering pump. Now the windshield washers. All in just a couple of short weeks.
Makes me terrified to own this car outside the manufacturer's warranty.
Window washer pump front relay - 30 Amp - position 39 - in rear fuse box.
Wiper fuse is not shared - that is Wiper motor module - 30 amp - position 5 - in passenger footwell fuse box.
I think I saw another thread somewhere here or in the Facebook group that the line from the reservoir got disconnected and basically leaked all the fluid out on their garage floor when they were trying to diagnose it in their garage. I think if you fill up the reservoir and try using it you should see wet spots in the rear and if so, you’ll know the hose got disconnected.
I thought that too, but I can't hear the pump running.
I located the fuse, its not blown. Unfortunately its not an going to be an easy fix.
I can hear a click in the box when I try to opperate the pump, no leaks, under the car and tank is still full.
To say that I am pissed would be an understatement.
My failed months ago, the part is on back order. Then suddenly this week it started working. Its a Lotus.
I had this issue the other day my pump just stopped working. I tapped it a couple of times with a screwdriver (I read someone mention this) and I removed the plug and reconnected it. Worked…. No idea.
