Luggage for Behind-Seat Shelf
geoffbland
Just in case anyone is after cheapish options for luggage that fit in the behind seat shelf I found these.
I measured the shelf and found it’s a bit of an awkward size; you can fit two fairly wide cases but that are not tall so they do not obscure the rear-view mirror. Meanwhile there’s a bit of depth to the shelf meaning you can go up to about 25cm deep not common for a smaller suitcase. Finally, it has to fit past the seat to get it in the back. Also to save a bit of height I didn't want tall castors on the bottom - just a simple pull along.
I found these. They arrived today and I can confirm two of these fit well on the shelf. There’s a smallish gap between them still that you can use for your other half’s neck pillow too.
These were the only half-decent wide, fat and short cases I could find.
I’ve not used them in anger yet but checked they fit and they seem fairly OK quality for the price.
https://www.amazon.co.uk/dp/B0B3245V2T
Edit: As pointed out below by KJD 56x45x25 is the standard Easyjet large carry-on size, so if you search on Amazon for this you find a lot more options.
Link doesn't work in the US, is this the bag?
Yes that's the same bag.
I should have included the name - it's called the "Flight Knight Cabin 22".
56x45x25 is the standard Easyjet large carry-on size.
There are many options available in that size.
I had two Samsonite semi-soft ones that fit perfectly on their sides, with room on top for some more stuff without blocking the rear view.
I think the biggest pro tip for any luggage (regardless of whether you are cramming it into the Emira) is to avoid casters and look for rollers. They just take up space and catch on every bloody thing (or get snapped off by rogue baggage handlers). And don't even get me started on cobbled streets!!
I measured the shelf and found it’s a bit of an awkward size; you can fit two fairly wide cases but that are not tall so they do not obscure the rear-view mirror. Meanwhile there’s a bit of depth to the shelf meaning you can go up to about 25cm wide not common for a smaller suitcase. Finally, it has to fit past the seat to get it in the back. Also to save a bit of height I didn't want tall castors on the bottom - just a simple pull along.
I bought two of these. They are perfect for the job. I also locate them with the roller wheels facing each case. I also adjust the main zipper to be along the side of the case, as when placed onto the rear shelf clothes can be taken in/out of the case for overnight stays. Only downside with the case being, if the weight is too great the top soft handle stitching can begin to break, it just requires gentler handling. Otherwise perfect as they are soft and compress with the seat as the seat is tilted back.
We've been into Europe three time so far with the Lotus (plus cases), the last trip in June was over 3 weeks to the Dolomites in Italy. No shortage of clothes, just too many (of the wrong type), thought it was going to be cold high up in the mountains as two weeks previous there was snow, so took hiking gear for snow but most had thawed.
Wherever we went people wanted to talk about the Emira. Some locations even offered parking places away from the crowds to prevent any marks etc.
The Emira was perfect on the mountain passes taking-in the steep, twisty narrow roads in it's stride. And when possible on the German autobahn 3 digit (mph) cruising was a regular feature.
Gone a bit off topic, but suffice to say, for me, my Emira is a perfect car, 2 ltr turbo, sports suspension, cup 2 tyres and adequate luggage space. Aside from minor software updates, I've only had one failure, a drivers side tyre pressure sensor and that's it in 8,200 miles. Long may it continue.
Thanks. This case was the only one I could find with a decent size that was the correct dimensions when I searched on Amazon, case by case. But as you point out if you search Easyjet case you get many matches. So there are quite a few other options.
All of that is useful information as we'll be doing our first trip to Europe in the Emira ourselves in August. A lot of that will be driving through Germany, Italy and the Alps.
You've probably sorted your route, but if your like us and we didn't, you may run into several difficulties. Driving through Belgium, Luxembourg, Germany, Austria and on to Italy sounds simple as it routes round France and the tolls. You also get to have a blast on the German autobahns. But as we found don't drive anywhere near Lille (France) as this is a low emissions zone and you'll need a sticker. Driving past Stuttgart is ok, but don't enter as this is also a low emission zone and requires stickers. Austria requires a vignette to drive through assuming you'll not be taking all the back roads and driving round the key junctions. All of these issues can be sorted before you set off, 2 to 3 weeks for Lille, 2 weeks for Stuttgart and Austria online before you drive in. Apart from that, you'll have a great time in the Emira and the Alpine passes are brilliant. Enjoy.
Thanks. Yes we have our route mostly sorted now. Had been using the RAC Europe driving website that mentioned the French sticker but not anything about other countires.
I have got the French Air Quality sticker as I had read it is needed in some places (like Lille) but also that there's other places that have it temporarily - so difficult to avoid.
I didn't know about the Austrian vignette so thanks for that - I have that one online now.
We will be driving past Stuttgart too but not going in there. But after you said that I looked up the German Low Emissions zones and there are quite a few cities now with this - including one where we are staying. So again thanks for mentioning that , so I'll get that sorted too. We'll end up with so many stickers on our windscreen we'll look like a primary school kids work book. :)
Edit: Looks like I need a vignette for Switzerland too.
I think these are all good options, however I opted to purchase a set of custom bags from Bagworld Bespoke Bags. I sent them photos of my car (interior and exterior) and they custom make the bags to match the car. A full set of 5 bags is about $1,200. It takes about 5 weeks to custom make the bags, I should have mine in another week or so…can’t wait. They have been extremely responsive to questions, and updates.
Bagworld Bespoke Bags Ltd
Windsor House, 5, Windsor Road, Redditch, Worcestershire, B97 6DJ.
It would be nice to see some pics when you have them.
I fit my roll aboard into the back of an Emira on our H2R2 road trip. I was pleasantly surprised. Of course it helps that my seat is not all the way back!
I am posting this as my set of 5 bags for the boot and behind the seat are nearing completion, however the Lotus logo was embroidered in Yellow, and my car is Osmium Silver with black and white badges. I was looking for white or silver embroidery on these logos. Colin at Bagworld suggested perhaps another member of the forum would be interested in these bags and he would then make another set with the silver embroidery for my Emira. If anyone is interested, please let me know. You would avoid a 5 to 6 week wait for custom making the bags, he said these will be ready for shipping out on Monday. If interested, I can send you Colin's information to arrange for payment and shipping. I have attached photos of the bags prior to being assembled so you can see the design. This is the full set of 5 bags, 3 for behind the seats and 2 for the rear boot.
As an American, this is the first I’ve heard about the stickers and vignettes. Is the idea that you’re buying stickers etc to purchase carbon offsets to allow your passage? Or is it simple tolls but you don’t have a Unified RFID tag system like our EZpass?
It's both.
I'm traveling through several countries in Europe and live in the UK. I now have for my Emira:
Electronic registration toll - Dart Charge - for crossing payment for the Dartford Bridge and Tunnel, UK
Electronic registration - ULEZ - for showing this is a green vehicle for driving in London
Sticker on Windscreen - Crit'Air - for showing this is a green vehicle for driving in certain cities in France
RFID Tag on Windscreen - Liber-t - for toll motorways in France
Electronic registration toll - Vignette - for toll motorways in Austria
Electronic registration toll - E-Vignette - for toll motorways in Switerland
Sticker on Windscreen - Feinstaubplakette - for showing this is a green vehicle for driving in certain cities in Germany
Plus a sticker on my UK number plate to show this is a UK car.
Some of these you can forgo and pay at the time but it is bit more hassle to do that & if you forget at the time you get some hefty fines (especially in Switzerland).
As far a "Unified RFID" - these are European countries we're talking about - you'd have the UK Independence Party up in arms even thinking about something like that! And as for France and Germany agreeing to some thing like that, fat chance. And then there's Switzerland....
It's both.
Thank you for explaining! Had no idea.
I’ve often driven rental cars in Europe, but it dawns on me I’ve never crossed an international border while doing so.
I used to use the Liber-t tool tag but when I was going to Italy last year found Bip & Go, an alternative that works in France, Italy, Spain and Potugal.
Same size as the Liber-t but slightly different mounting tab.
I’ve hidden mine behind the mirror shroud:
Works out slightly cheaper but you need to set up an international payment as they don’t have a UK office.
