Ok, besides having to now have the valve calibrated that
@lynchy73 and others have mentioned, it’s important to note that doing this on quickjacks, is a pain. I would say if you have access to a lift, use it!
First obstacle, the OE i4 exhaust is big and has an additional mounting bracket dead center. See pic…
Next problem, the OE decat pipe (no third cat on i4) has a spot weld that unfortunately goes through the pipe making it essentially un-removeable. See pic…
Now next problem, because we couldn’t remove the decat, we couldn't squeeze the exhaust out. So after an hour of twisting and turning, I made the call. Reciprocating saw! See pic…
After that, getting it out was a cinch! Oh yeah,
I skipped one other big headache, the V band clamp around the down pipe and decat. Getting that off was super hard because of the placement of the bolt. I don’t know how many extensions, elbows, etc. we used, but we finally broke it loose.
All in all, it was cool we did it, but it was a pain. BTW, you if you watch the cool install video on one of the other threads for the GRP titanium v6 exhaust install, it seems straight forward. However just know that the i4 is at another level of complexity if you don’t have a lift,
the V band clamp on the down pipe to decat connection access, the spot weld that went too far on the decat preventing its removal, and finally the center bracket that got in the way of removal because the OE box is so big.
Lastly, as a reminder I got the v2 and it is beautiful(see pics earlier in this thread), even more so after a little blood (knuckles were busted), sweat and ok maybe one tear of joy when done!
