Eventuri development
Time2Fly
Denver
Yes. And while the intake will void warranties (they even sent out a letter stating such on etc Evora) it doesn't void everything on your powertrain. They have seen issues with data transmitted between the ECU and the TCU (automatics), where the TCU is trying to calculate torque levels, but is confused in shifting because the engine exceeded more than set calculations predict. You AC, wheel bearing, windows, steering are all unrelated along with a long of engine items too that would have to be proven to relate to you mod.
So it's less of an issue on a manual?
finny76
EMIRAAA
DFW, TX
Does anyone know when Eventuri High Flow Air Intake will be available for the EMIRA?
seriously
Orange County, CA
I wish this Forum was a section in the Lotus Talk Forum rather than this stand alone. So many questions that people ask can be answered by reading the Evora and Exige V6 sections of the LT.
While the driver interface electronics, chassis and interior are different to that of the Evora, the drive train is the same, drive train layout the same and so much has already been learnt over the last 15 yrs of the Evora. Specifically here, LHS intake feeds engine intake and RHS has a fan assist feeding cooling air into engine bay. Air will also feed in from scoops on under tray to cool surrounds of engine, exhaust and transmission flowing up and out side hatch vents and gap at rear of hatch. Forward main radiator provides water coolant for engine and to a water-oil heat exchanger mounted on top of the transmission. SC uses an air-water heat exchanger piped to an other radiator in a nose side duct to cool air intake charge after the supercharger has compresses it. Attachments from Evora Service Manual; while Emira is similar, layout and components will differ so no responsibility for any mis-information.
Reminding me that coolant lines on mid-engine cars are no joke. Hope to never have to maintain.
Porter
tap tap... is this thing on?
DC/Virginia, USA
Keep the coolant fresh and change it regularly if you want the hoses and gaskets to remain healthy over the long term. I would go max 2 years between coolant drain/fill with fresh fluid.
Julian73
E. Texas
Lotus uses Toyota Super Long Life Coolant. While I would not trust it for the 10 year life span, I believe its safe for a 4 yr drain and refill interval. I even use that cycle on my track cars. Now back fluid is another matter, that corrosive stuff I change annually if not more often.
Davebeats
Tampa FL
Daz205
Bristol
I have one of their intakes & plenum on my m3 v8 and can commit to the build quality
My only question is why does the Rev limiter / drop off kick in @ lower revs with the intake fitted ?
Or am I being dumb ?
Eagle7
Emira Aficionado
United States
Just under $1600 stateside
Greg's has it listed at $1,545
Yeah that sounds like a lot for a cold air intake, but the results are also pretty good. Being able to add 12hp and 8 ft/lbs of torque is nothing to sneeze at. That gets the power pretty close to the 416 everybody was expecting the car to have, and it's consistent across the board, not just at the top of the rpm range. It's cheaper than a tune, and may just be the extra added oomph people want. Hopefully we'll get a video review with sound clips soon.
