AutoX Pro using DEX via Galaxy Fold 7
Kaz
After some back and forth I finally read the instructions, updated firmware and plugged in the AutoPro X into the USB C port in the armrest console. The unit itself is a small circle, very light. Your phone connects wireless to the AutoX Pro.
This allows you to use DEX or Android Auto - the party trick being anything that works on your phone can now be used on your screen, including YouTube, Netflix etc. It works pretty well, framerate is not a smooth 60hz probably more like 30. I haven't figured out exact aspect ratio control (the Emira screen is wider than 16:9) but there's probably a screen ratio control somewhere.
While DEX is running your phone can do whatever so if I'm doing this I'll just run Waze on my phone and whatever video on the main screen.
I'm guessing that with a Samsung S23 you can't connect to two bluetooth accessories at the same time? Would be nice to connect to an OBDII reader and the AutoX to display gauges, etc.
