- Joined
- Nov 20, 2021
- Messages
- 2,915
- Reaction score
- 6,048
- Location
- United States
- Emira Status
- Emira Owner
Featured
- #81
Those are high offsets. 45 is usually the highest on a 3rd party wheel. Hopefully the Emira isn't that bad, but if it is, that pretty much rules out off-the-shelf 3rd party wheels. I hope these "ultra light" wheels are indeed ultra light. I wonder what the engineering reason is behind such high offsets? That moves the wheel inward, which would mean the hub/rotor is outward a bit farther than usual. It's not a huge amount, like 3/8th of an inch, but still interesting in light of how experienced Lotus engineers are for chassis development.The Emira supposedly comes fitted with 20x8.5 and 20x10.
Lotus offsets are extremely high. There's a possibility that the manufacturer won't have an offset appropriate to the Emira fitment. You can use Evora offsets as a rough guide. We don't know what the Emira offset will be yet but it's almost certain to be higher than typical production cars.
From the Lotus service bulletin on wheels from September 2017:
Clearance isn't actually the most important consideration around offset, at least not in the front. The main reason to match the offset as closely as possible on the front axle is to retain the steering axis point. If you move the center of the contact patch outward (lower offset wheel in the same width) it causes the wheel to move through a slight arc as you steer. There are a ton of handling implications, some of which are benign and some which are more undesirable.
