đź““ Journals kitkat's Emira
Been toying with the idea, will play around with it this fall/winter.
Before you ask:
- Yes the reverse lockout would need to be removed to make the shaft thinner, an entirely new shaft may actually be needed.
- Unsure how if I can come up with a mechanism to keep the lockout in place or not.
- Yes this would have some side to side adjustability.
- Unsure about spacing from gate to gate or throw length -- will be experimenting with that.
- Would probably get the base made in 6061 gloss black anodizing and the top in 6061 brushed aluminum to attempt to match the existing surrounds.
Before you ask:
IF you decide to sell this.. Count me in.. I can give you money now. :)
Before you ask:
Can this be mg?
lol chances are this will be a one off project for me, it most likely won’t work on any other car
If I can make it work for multiple cars I'll figure something out, but this is Lotus we're talking about, the variability from shifter to shifter isn't like +/- 1mm, it's more like +/- 1cm.
cm... mm.... Same difference.
Bad news, the shift gate is a no go.
I was planning on making a brand new shift lever with a thinner profile in order to pass through gates, but unfortunately this shaft is welded to the lower portion of the ear. Part Number 3 below:
This is necessary because I can only really work with a 10mm diameter shift lever to get a reasonable shift pattern in place. Right now that diameter is 14mm which means I need closer to a 15.5-16mm shift gate width -- basically the H pattern goes away completely at this diameter.
- Replicating this part from scratch is way outside of my abilities.
- Putting #3 into a lathe and trimming it down to 10mm diameter is possible but it's irreversible and will no longer work with the oem reverse lockout sleeve. This is a permanent modification I'm not willing to do.
- A new #3 can't be purchased alone, it comes with the entire shift assembly and costs $1500.
Fun while it lasted :)
Can't win em all. Just means more time and energy freed up for your next idea. Keep at it 👍
