Front splitter only
Ok, thanks for the info. I'll check the rivet nuts out. I believe the GRP install uses them.
Yes, as @PP4 mentions above, you don't need to remove the under tray. I also used rivet nuts and only drilled 1 hole for a rivet in the center for the middle section of the splitter, which actually has 2 holes close to each other. I found that using only one of them was more than sufficient to keep it sturdy in that middle section.. As for the 2 extreme ends of the splitter, I used smaller stainless steel self-tapping screws. I didn't even use double sided tape nor any other type of adhesive as the splitter felt firmly attached with the rivet/bolts and screws alone. Hope this helps.
