Engine speed related squeaking/dry bearing noise?
eclat2emira
Hi, a noise has developed over last few weeks and wondered if anyone has similar and had it diagnosed/sorted?
Heard for some time after start-up, it's like a sqeaking or cheeping, chirruping noise. Engine speed related, seems a bit louder under load and still there if clutch dipped and/or in neutral. Sounds a little bit like a dry or worn water pump bearing would but does not sounds as distressed or metallic/mechanical. Could it be a drive pulley or something like that?
Any thoughts and ideas welcome! Other than that, 1800 miles in she is driving like a dream!
Sounds like an idler pulley with a bad bearing, or possibly a bad bearing in one of the accessory drive pulleys.
Does the sound change with AC running, or with steering input off center?
That's where I was leaning towards, will check both of those suggestions and report back - thanks.
I sometimes get a bit of a squeal on the Elise from the supercharger belt if it’s got wet. Is that a possibility?
And there we were a couple of weeks ago having a happy conversation about how our Emiras were both trouble free :)
Bit of a shame we are tied to Parks for issues like this under warranty as I suspect Craig Moncrieff just down the road from you in SIghthill would be able to diagnose and fix it very quickly.
Do you think it is possible that it is coming from the Engine compressor?
Maybe you can make a Video
I'm not classifying it as a fault yet Mark! 🤣 Hoping it may be a drive-belt noise as suggested - will run some tests tomorrow.
Did you ever get to the bottom of this? A few of us are experiencing this with our V6 Exiges, those with the same engines as the Emira, after we put on new drivebelts.
Sadly not yet! My Emira is currently in for its first service and of course the noise has not manifested itself while it's been in. It is only evident on first start up of the day, once the car is up to temp (10-15 mins running) it disappears, usually for the rest of the day, unless the car gets the chance to completely cool down again. I'll keep you posted - and please let me know if you hear of any clues regarding source of this.
Hopefully you don't have this, but if it's more of a rattle than a squeak it could be an intake cam pulley VVT mechanism issue. It can happen if there are any oiling issues with the 2GR-FE. That particular issue is detailed in the following deep-dive, which is worth watching about the 2GR-FE generally. We have a much later variant of the motor compared to what he's describing, but the sensitivity to oil pressure and quality remains in all variants. I wouldn't go 10k miles between oil changes personally, I think 5k miles is max on this engine for the kind of load states being generated with the supercharger.
There are a couple of different "squeals/squeaks until it warms up" issues that are covered in different parts of this video. It will give you a few different things to think through.
Did you ever get an official answer or fix from lotus on this? Mines had it and is going into lotus in a few weeks under warranty.
Hi, this was just before first service 12 months ago and of course it did not manifest itself while in the service dept! I did quite a bit of research, the most likely answer being it was a bearing somewhere in the drive belt system where the outer shell was spinning within its housing, which then disappeared when the engine was was warmed up and it became a tighter fit. It has not reappeared since, so I'm hoping the outer bearing race is now firmly lodged in its housing. I found this info on a thread on Evora engine issues - hope that helps!
