Emira Turbo (i4) Upgraded Exhaust Sound Clip
675430VME
Emira of the Month 🏆
Full exhaust system (Down-pipe without GPF, mid-pipe, and rear exhaust) with OBD active value control. No warning light.
Those shiftings are amazing!
What's the setup of the car to reach those 0-100 numbers?
How did you manage to disable the OPF/GPF on the ECU?
@675430VME very nice exhaust sound. 💪😎
Could you please list all of the parts of your exhaust system. Thank you.
Mach5 200 cat downpipe without GPF, Boomgear titanium full exhaust system with heat protection and upgraded value unit plus OBD active value control.
Mainly because of a pair of Recaro 2600A. A proper exhaust system will not trigger any warning light, so no need to disable anything on the ECU side.
Comparing to the V6, sure no argue there.
I'd argue. They different that's all. My i4 with a similar set up to yours sounds amazing. Pops, bangs, whistles, air dumps, etc. There's theatre everywhere. Plus it absolutely smashes the V6 on the road and on the track. The V6 has a great exhaust sound... and that's about it.
TurboTambo - are you able to confirm the stock exhaust system only had a Single Cat no Secondary cat? thanks
Beautiful wrap on that car. Too bad there is no before and after Dyno.
