Wonza
Manchester
Yup. Cracked by a stone.
But it’s turning into a big adventure.
Screen #3 will be fitted soon, hopefully.
I’ll file a report when the story concludes.
Wow what’s the availability of the windscreen from places like autoglass. Are they always in stock? Or did you have to wait weeks? Lotus or aftermarket windscreen?
KJD
London/Surrey, UK
I’m using Autoglass through my insurance.
There’s no aftermarket alternatives yet (unsurprisingly) so they (eventually) ordered an OEM one from Lotus.
They fitted it very well. Until they broke the DAB aerial connector.
Hence #3. The glass is £2k a pop. Expensive little connector (for them).
NeilS
UK
Now I'm worried Lotus may have damaged the DAB connector in ours at the factory....
virtualmacho
Supporting Member
Tokyo, Japan
Yikes, that's awful. Did you catch the kid who threw it?
Off topic, but while your bonnet/hood is open, do you have view to the inside of the front bumper (smooth inside or filled with ribs, directly in contact with metal sub-frame or floating on brackets) ? Just considering the possibility of "hanging" the front number plate from the upper lip. Thanks.
FederGigant
Germany
Where did you get the tool to unlock the hood (bonnet?). I saw a video of someone using the tool. Apparently, this is necessary if you wish to replace the air filter.
The „tool“ should be in the same bag as the tire repair kit in the trunk, however it‘s just a standard Torx driver.
KJD
London/Surrey, UK
From memory, the inside of the bumper isn’t particularly accessible.
There’s a cross member of the subframe in the way at least.
I’ll try to remember to get a pic for you next time I’m in there.
KJD
London/Surrey, UK
It’s a possibility. Or maybe they forgot to connect it.
FYI, the DAB aerial is in the RHS of the screen. You can see the two dipole wires going up and down at the side.
Here’s a pic of the FM connector, on the LHS. Didn’t focus on the relevant bit but you can see the ribbon cable coming off the screen looping into the box on the A-pillar.
The DAB setup is a mirror image on the RHS.
GAVLA
UK
My windscreen was cracked by a stone last weekend. Luckily no bodywork damage and the crack is not eye level. Contacted my insurance this morning to claim for a replacement. Do you know whether there's any special technology in the windscreen that would make replacing it a problem?
KJD
London/Surrey, UK
No, it’s pretty conventional.
Unlike the Evora for example, which had external A-pillar trims that were notoriously awkward to fit properly.
As I said, the Autoglass guys had done a good job of fitting the glass. It was a silly problem with the aerial that cocked it up.
GAVLA
UK
Thanks. I will check they don't damage the aerial in the process - as it happens my DAB radio isn't working anyway 😢
scoates
Scotland
Copied from my "Scoates' Magma Red Emira" thread:
I have also noticed a more concerning issue. There is paint beginning to bubble up on the passenger door. Just noticed today and can't think of anything to have caused it. I've not put any coatings on it, there has been nothing left on the paint to etch in, and only washed with a plain shampoo from Autoglym. Will definitely be getting in touch with customer care ASAP about this one!
Visible in the last image if you zoom in around where the shadow from the wing mirror is. Also some orange peel visible too...
Peeltone
Shropshire
There was a thread on seloc about a nimbus with similar issue. Hopefully this isn’t a thing to come sorry to see this for Scoates.
kitkat
Emira Degenerate
Mountain View, CA
Man I don’t even know what to say @scoates , really hate that this is happening to your car.
It’s just issue after issue with the Emira.
Magicman
Nottinghamshire
On the dab have you just got no stations? If so drag down o the screen to refresh and they all should appear
BeHappy
County Durham
So taken almost nearly 6 months for issue to show - as Scoates was an early delivery Nov last year - wonder if this has any bearing and this an isolated issue that won’t be seen on later cars ? - Emira also doesn’t like Scottish weather
jamesbxxx
West Midlands
I had a similar issue with an Elise when left outside in the damp under a cover. Water coming from the inside through the porous body material and getting trapped under the paint. Most of the bubbles went away once the body dried out properly, without any lasting damage (only stretched the paint on one or two large bubbles)
  • Useful
Reactions: ino
shaank
Edinburgh
Oh water, water, water.
Front loom corroded from water damage. Massive job to replace. Emira away again for 'TBC length of time'.
More details in my ownership thread.
Toomanyloti
UK
more like salty water damage.
Mine just dont go out in that sh!t period...
