BeHappy
Can’t post link but a few more owners experiencing engine management light on FB
On another note, Lotus is not making the brakes in house, so this is most likely a supplier issue or as someone said a checmical came into contact that eroded the brakes. Could be a one off situation. Agree with Tom, Hethel should have sent out an engineer to look at the issue right away, clearly that is not normal. The lack of supply is the bigger problem.
That sounds very rational and if it were another brand, I may believe it. Unfortunately, Lotus doesn’t have much credibility with me.Remember it's more likely people will come on the forum and post about issues they are having (and see others reporting elsewhere) than posting about the miles of trouble-free motoring they are enjoying. Those people do exist and some have posted online on here and other forums, Facebook, Instagram, YouTube etc. I've had messages and calls from several of them.
Lotus understandably aren't going to publish figures on the rate of issues. Based on what I've seen and heard, I think 5-10% of cars delivered so far have had a major issue that has either stranded the car or required an unscheduled return to the dealer. Around 15% have reported issues that are annoying but not critical and can wait to be solved whenever the car is next at the dealer.
I think that's quite a high rate, but Lotus do seem to be acting on them quickly. I believe the slowdown of new deliveries and updates to deposit holders about further delays are because they are fixing these issues on cars built but not yet delivered, and putting mechanisms in place to ensure they don't occur on future builds. That's the right action to take, even if it adds further frustration about delays. If they told people what was going on it would probably help too, but we know they don't do communication well.
If an issue needs to be fixed urgently on several cars then they will do a Recall Notice for a range of VIN numbers (as they did with the steering pump issue on very early cars). If something needs to be done next time the car is at a dealer then they will issue a Service Bulletin. This is all normal practice for any car company. These documents will be published and owners will be able to access them.
If you go on a porsche forum you'd think all of them spontaneously implode. I've had 1 lemon in 15 porsches. Which was the first cayman s on launch day back in 06That sounds very rational and if it were another brand, I may believe it. Unfortunately, Lotus doesn’t have much credibility with me.
Not doubting you. Doubting Lotus.
About 26 cars (Oct.-Dec.) have already been registered 2022 in Germany so far.I know about many more delivered cars than that, nearly 40 of them where I know who has got them and about 75 known to have been delivered in the UK. As I say, about 1 in 10 with a significant issue.
I believe this.updates to deposit holders about further delays are because they are fixing these issues on cars built but not yet delivered, and putting mechanisms in place to ensure they don't occur on future builds.
Great to have some positivity, how many miles have you put on it ?I picked up my Emira recently, no bad paint, no warning lights, no limp mode, no bad door weatherstrip, no tangled belts etc. Some may say 'yet' but I can only report as is.
Just a gorgeous looking car that is great to own and drive. It's one thing test driving them or looking at dealer cars but when it your own it its a whole different delight! I do understand maybe I have been lucky. Obviously It's a shame some def have had issues but lets be a bit more positive
It has been depressing looking at a lot of posts, so much negativity has nearly stopped me even visiting Emira Forum which would be a shame as some great contributors and lots of worthwhile info. Mostly.
Quick update on this one to confirm I found a document in my owners folder “EC CERTIFICATE OF CONFORMITY” which is dated 15th November.Not exactly but it was long enough to drain the battery which resulted in errors / warnings about the battery for the first few days until I was able to give it a longer run on the motorway and charge it.
I was told this was the same for most / all vehicles delivered following the cold spell mid December.
Mine was dated Nov 8th and delivered Dec 23rdQuick update on this one to confirm I found a document in my owners folder “EC CERTIFICATE OF CONFORMITY” which is dated 15th November.
The service book has a pre-delivery inspection stamp by Lotus dated 23rd November
The car was delivered to me December 15th
Unsure where it was throughout this period of time but probably out in the cold hence the very low battery and corroded brake disks.
T | Emira with NO issues? | Canada | 22 | |
B | Who has actually had issues with the Emira? | Lotus Emira Problems and Issues | 27 | |
Anyone got an Emira with zero issues?! | Lotus Emira Talk | 123 |
