Emira - Adjusting Camber
bshads
Does anyone have a guide for adjusting Emira camber?
I'm assuming it's shim based and if anyone has this info, it'd be helpful.
- 1mm shim = roughly how much negative camber
- Is there a specific geometry to the shim or would most u shaped shims fit?
- If specific, does anyone sell a kit of various thicknesses?
After installing coils and corner balancing, am noticing less camber on the right side of the car by 0.3 deg F/R and in general would like to have about -0.5 degree less per side after balancing L/R.
No it's not shims in this car and the adjustment is fairly limited.
Stock ride-height you can expect -1.5 to -1.8 degrees of negative camber at the sacrifice of caster the more negative camber you go.
Further suspension modifications are required for more aggressive alignments. If you're just looking to even things out then an alignment shop familiar with adjusting double wishbone suspension cars should have no issues.
Manual attached for your reference for front and rear.
Thank you! This is super helpful.
And my alignment shop didn't fully investigate last time because it's me, and I was pressed for time to get the car ready for a track day. Was only able to get through corner balance and ride height setting then a quick toe check before needing to get going. Will set the cambers and re-check toe over the weekend.
