Does the US version have OPF?
Milk242
My Specs:
Emira I4
I’m in talks with mach5 performance looking to buy their downpipe for the i4, but was asked if the US version has OPF. Does anyone know?
Unlikely?
I had to google OPF (otto particulate filter). This is synonymous with GPF (glass particulate filter) and in the i4, there is no specific GPF like the v6 has.
But @Kaz changed his DP to the Aerie and his race shop think that because our i4 has such a huge honking cat, there is probably a GPF in the OEM cat. I have the GRP cat to install yet.
One thing you’ll have to let Mach5 know though is that the US model cats do not have the two DPS (differential pressure sensors) going to the cat so they will need to supply you with aluminum or stainless caps for these two ports.
And you should probably ask Mach5 what their recommendation is if you should throw a post cat O2 sensor code after install. The Aerie cat throws codes, dont know if the GRP one will yet. But Kaz and I have 90 degree bend sensor spacers to try to eliminate any post cat O 2 sensor codes.
Btw, when you message Mach5, ask them if they are working on an upgrade for the AMG w177 heat exchanger intercooler. They already have one for the AMG w176 system. I messaged them but never got a response. ;)
Thanks for the photo, I sent it to them and they have a version without those 2 pipes and claim no CEL.
Yea they aren’t really responsive via email or IG, but super responsive on WeChat. I’ll ask them about the intercooler. I am also trying to buy their obd2 enabled exhaust valve controller but not sure anymore since jb4 will also need obd2 connection.
There is an OBD splitter, which I also need when I install my JB4
What brand is your valve controller? Mach5 says specifically they no need to connect to obd2 so not sure if they meant there is no obd2 connector or if they just meant no need to connect
That OBD valve controller is not from Mach5, ask Ryan, he has the whole kit including a mounting plate for valve motor relocation.
Valve controller is for your cat-back muffler system, nothing to do with the Mach5 downpipe.
Yea I know, just saw they also sold a valve controller but they said theirs don’t connect to obd so was curious what brand you used as milltek also doesn’t connect to obd.
I got mine from Ryan when he installed my exhaust, could be one of his in-house products.
yeah it's not rocket science for the codes in region specific cars...either the replacement cat is high enough cell count that it is doing enough to be within range or its not - and the sensor extension is just far enough away to run cleaner without being too far away that the voltage reads too low and that itself will trigger a code. I assume you can just trial and error with 90 degree bend or mini-cat attachment until your car is happy. They are all the same, tube of metal with a more free flowing cat and some extensions for the sensors.
As far as I know, some of the cats, like mine, produced in China have a special layer of mineral on the inside of the cat so there is no need to mess with the sensors.
They do sell a heat exchanger and intercooler, seems like they don’t have any distributors in the US though.
They have one already specifically for the w177? 😳
Last I looked on their website, they only had for w176. Will look again... 🤔
I dunno if it’s on their website. I’ll ask for some pictures. I suspect that at the very least the charge cooler will be the same as any m139 engine.
They sell snowtech products. They said their downpipe and snowtech products all come from the same factory lol. They offer an after charge cooler charge pipe with methanol/water injection bungs. Not sure if it’s better to inject before or after the charge cooler.
From what I know, the Emira i4 US and China versions do not have OPF/GPF, but they do have a typical catalytic converter and that’s actually one of the reasons they come with slightly more power compared to the EU versions.
In Europe, they definitely have OPF/GPF — I’ve done some diagnostics on EU cars, even with very low mileage, and I’ve already seen error codes related to OPF/GPF regeneration issues. So it’s a confirmed difference.
I’ve also sent a few emails and Instagram messages to Mach5 Performance, but unfortunately haven’t received any reply so far.
At the moment, I’m in touch with a few colleagues and we’re looking into the possibility of adapting an ECU from a US or Chinese car to the European version, in order to be able to install the downpipe properly.
All Emira Turbo have GPF in China. Instead of swapping an ECU (much harder task) maybe you should just try the Mach5 downpipe. Mach5 uses special mineral inside the downpipe to pass CEL, however once its burnt off then it will trigger CEL. This is how tuners in China getting rid of GPF when they can't flash ECU, usually it will be good for a few years depends on driving habit.
