Blendmount for Emira
Fasttoys
Texas
I tried to pull off the cover, to wire tap but luck too chicken to pull hard.
If someone figures out how to remove the cover please let me know
When I get my car in a month if my usb doesn’t work will have a full write up. Do you have V1 2.0? Wonder why escort and others work? I use this cable in my EV Etron GT no issues & others with V1 but not in Emira since mine has not arrived.
virtualmacho
Supporting Member
Tokyo, Japan
MIGZ
Over The Moon
So strange, just powered my V1 2.0 and did the most resent update while plugged into usb without any issue. Do you have the one that works with 12V? Plus look for any that says Note: This USB RJ11 Radar Detector Cable is not suitable for Valentine One radar detector. Good luck. What blend mount model number. Try this one:
Missing link attachment
MIGZ
Over The Moon
I took a look at it today to try an pop the covers off but was hesitant to pull too hard so still no radar
T6061
San Clemente, CA
BMG-2024 works with Escort Maxcam360c
Does the Escort get enough juice from the USB jack or is it hardwired to a 12v source? Possible to get a couple more pics of the instill from different angles? How happy are you with the Escort Maxcam 360c? I've always been a Valentine 1 user but having one unit to provide dashcam and radar detection has a lot of appeal. Many thanks for your insights!
L
Lsp408
Knoxville
  • #47
Just tried it and the USB by the rear view mirror did not have enough juice to power Maxcam360c
Wow_Bao
Allen
Mirror Tap is not needed. Cleaner install All we need since the mirror plastic housing on the windshield has a USB connector for video and radar setup, it's on the passenger side. Amazon: Radar-Detector Cable, USB to RJ11 Plug Cable, for Escort Radenso XP Uniden Beltronics Cobra Whistler, V1, Radar Detector, Replacement Power Cable for Radar.
,V1
Do you have the direct link to this because all of the one I’ve found is 3.3 ft long.
