10mm hubcentric spacers
Does anybody know the exact length of the hub spigot? And also if the original bolts are M12 x 1.5 with a 26mm thread?
12.0mm on my calipers and you are correct on the original wheel bolts.
Odd, PCD stated they could only manufacture 10mm hubcentric if the hub spigot was less than 10mm in length...hmmm
Exactly! I just spoke to Charlotte and i was informed that the minimum hubcentric spacers they could make is 12 mm due to hub spigot being 12 mm.
I emailed her back and stated that they have made 10mm for others in past.....maybe those 10s became troublesome so they moved away from producing them unless the specs of the spigot comply?
Their response:
Thanks!
Well... on that case, can you please confirm that the front spigot is different from the rear one, that is 12mm?
Thanks!
Unfortunately not anytime soon but I bet others on here can confirm..
Charlotte just e-mailed me today to ask if I had any issues with my 10mm spacers from them and I confirmed than none whatsoever, in other words they fit perfectly on my Emira and performance-wise produced no vibration whatsoever at any speed.
I gotta say, PCD has incredible customer service. Charlotte was on this from get go.....thanks so much
But they were hub centric, right? :-)
