USB port near rear view mirror is intermittent
azlambo
Phoenix, AZ
Hooked up my radar detector to the usb port near the rear view mirror, using a voltage booster transformer to get the 5- volt usb port up to 12 volts. Sometimes the usb port works and sometimes it doesn’t. Anyone else experience this?
Time2Fly
Denver
I thought it required the engine to be running.
KAR120C
Get off my lawn!
Noblesville, Indiana
What model is your detector?
MIGZ
Over The Moon
I tried similar approach, ended tapping the mirror. V1G2 need consistent 12V mine would not work from the USB
Superman
Emira Owner!!
Berkshire, UK
Likelihood of usb port itself being intermittent = unlikely (likelihood of usb port in a lotus being intermittent = some might suggest somewhat more likely, but I'll still put it in the unlikely bracket); likelihood of a 5V to 12V mini transformer not being able to supply the required amps from the usb socket = WAY MORE likely!!
silent cilantro
PsymonR
County Durham
So stupid to put a USB power cord in the mirror and not provide it with enough juice to power a radar detector. WTH?
The USB in the mirror surround is most likely there with dashcams in mind rather than radar detectors.
As a note, radar detectors are illegal to use in the majority of Europe, they are legal in the UK but generally not widely used.
A
azlambo
Phoenix, AZ
  • #13
I think you are probably correct! The probability of the usb port being intermittent (even in a Lotus) is pretty low.
The in-line step-up power converter is probably at fault. I found another supplier that says his works with Valentine 1’s…..we’ll see! Fingers crossed!
Nick Sticks
Ipswich
That's exactly what it's for.
ttvetdoc
Charlotte, NC
What mirror mount are you using.
That's a Blendmount. I have a Blendmount in my Emira as well for my Escort detector. Not cheap but very high quality and so much better than the suction cup mounts.
