USB port near rear view mirror is intermittent
azlambo
Hooked up my radar detector to the usb port near the rear view mirror, using a voltage booster transformer to get the 5- volt usb port up to 12 volts. Sometimes the usb port works and sometimes it doesn’t. Anyone else experience this?
I thought it required the engine to be running.
What model is your detector?
I tried similar approach, ended tapping the mirror. V1G2 need consistent 12V mine would not work from the USB
Likelihood of usb port itself being intermittent = unlikely (likelihood of usb port in a lotus being intermittent = some might suggest somewhat more likely, but I'll still put it in the unlikely bracket); likelihood of a 5V to 12V mini transformer not being able to supply the required amps from the usb socket = WAY MORE likely!!
So stupid to put a USB power cord in the mirror and not provide it with enough juice to power a radar detector. WTH?
The USB in the mirror surround is most likely there with dashcams in mind rather than radar detectors.
As a note, radar detectors are illegal to use in the majority of Europe, they are legal in the UK but generally not widely used.
I think you are probably correct! The probability of the usb port being intermittent (even in a Lotus) is pretty low.
The in-line step-up power converter is probably at fault. I found another supplier that says his works with Valentine 1’s…..we’ll see! Fingers crossed!
That's exactly what it's for.
What mirror mount are you using.
That's a Blendmount. I have a Blendmount in my Emira as well for my Escort detector. Not cheap but very high quality and so much better than the suction cup mounts.
